Sent from my FaeaF2 using Tapatalk
Cyanogenmod 10.1 Neo X7
Well, on my travels around the internet, I came across a port of Cyanogenmod 10.1 for the Chewi v88 on Rkcrew. I've installed it on my X7 with Phjandersons kernel and it works really great, so far its one of the smoothest Roms I've used and I've had no shutdowns.Problem is Wifi and Bluetooth don't work, only Ethernet. I'm guessing I have to copy the stock WiFi and Bluetooth modules and then run an initd script to get them to work. Can anyone tell me where I can get the modules from or even upload them for me? I'd be very grateful!
Sent from my FaeaF2 using TapatalkTags: None
P.S here's a link to the ROM. http://crewrktablets.arctablet.com/?p=1950
Originally posted by Batfink32 View PostP.S here's a link to the ROM. http://crewrktablets.arctablet.com/?p=1950
Re: Cyanogenmod 10.1 Neo X7
Originally posted by peety View PostYou could use the RK3xxx firmware tools to do this your self. Do a search here You will find it. Or there is a similar tool posted on XDA and here too? Cant rememeber. But both will allow you to add libs you need.
Yes you need the right kernel but you also need the support files
rkwifi.ko
wlan.ko
The module for the wifi chip which is in /lib/modules or in /vendor of the stock ROM
Basically do this:
copy from the stock ROM everything in
/system/lib/modules
/etc/firmware
/etc/wifi
/vendor/lib
/vendor/firmware
and you may need wpa_supplicant from /system/bin
That should get wifi working. BT is another matter.
Originally posted by Finless View PostYes you need the right kernel but you also need the support files
rkwifi.ko
wlan.ko
Basically do this:
/system/lib/modules
/etc/firmware
/etc/wifi
/vendor/lib
/vendor/firmware
Thanks Bob, trying it now. Why is bluetooth more difficult to get to work?
Originally posted by Batfink32 View PostThanks Bob, trying it now. Why is bluetooth more difficult to get to work?
Originally posted by Finless View PostBecause BT is enabled all over the system. Get wifi working and then I will tell you what to do about BT. But even if you do copy over all the files, the framework itself maybe different in how settings turns it on, etc.
Argghhhh,i cant get it. Just keep getting bootloops. Its a real shame because this is probably the best Rom ive tested,so smooth and fluid.
There are currently 2087 users online. 1 members and 2086 guests.
