Sent from my SAMSUNG-SGH-I537 using Tapatalk
Yuandao N101 Finless/RileyROM 2.1
Re: Yuandao N101 Finless/RileyROM 2.1
Originally posted by taishou View Post
Sent from my SAMSUNG-SGH-I537 using TapatalkRandy
Yes I did a hard power off after first boot. Even after flashing and resetting the battery stats the tablet shows 1% left. Without the charger it immediately shuts off but in CWM mode it is working for hours. The battery panel in settings says 0s on battery.
Is there another kernel version I should test?
For me, it took a really long time to charge the first time.
If you can find it...try the Rimless 1.6 ROM
The first charge after flashing the old ROM took about 10 hours to fully charge. Once I did that, I was able to go back to the current ROM and everything seems to be working fine.Randy
Sounds like you have a hardware problem.
I have not experienced video playback problems on mine.
Flash ed rrileypm;126723]I have not experienced video playback problems on mine.
Sent from my SAMSUNG-SGH-I537 using Tapatalk[/QUOTE]
Oky, Thank You for fast response ... I try to reflash now.
Edit:
Flashed again with default setting ...
Video and movies won't play in stock players
Installed Es file explorer (with integrated player)...nothing...
Installed Mx Player and work only desabling H/W decoder...
Work well with Mx and S/W decoder for audio and video both.
All other works well also.
Thank You for support and Happy new Year from Italy...!
In case I am not able to solve the problem do you know a trick how to prevent the tablet from powering off automatically?
Charging issue
Originally posted by taishou View PostThis could be...I can live with a wrong battery status but not with a permanent connected charger
Also it happened to me that charging the tablet remained steady at 47% for more than 3 hours, then I went in the settings of the WiFi and I realized that it was set to "always on" ...
When I changed the setting to "only when connected" the tablet is fully charged from 47% to 100% in 2 hours!
Guest
There are currently 4180 users online. 0 members and 4180 guests.
