Android 10 q with desktop mode support for amlogic s905x3
see::
under requirements
Anyway...
if seek a Desktop mode on a android TV box,....
Google market search : Sentio Desktop (launcher ) and Sentio app
it looks like windows GUI... for android even supports window/resize mode for apps
and if wish dual screen ( mirror ) try displaylink (device) with displaylink app
works on most phone/tabled/tvbox
cheers
"Desktop mode" in Android 10 is a second-screen function, meaning it is a phone feature to connect a 2nd screed monitor to use that extra feature and functionality, so on a TV box device you only have one input for screen connection the HDMI port.
If you really want a powerful Android TVbox setup you'd buy yourself a refurbished Google Pixel 2 or 3 and use the device with a powered USB-C hub connected to your TV or Monitor permanently, because that would be the best way to use Desktop mode correctly with the latest Android security patches.
There are currently 2016 users online. 2 members and 2014 guests.
