Custom Rom for TICTID 4GB RAM 64GB ROM TX6 Plus
TICTID is just a Trademark Brand, meaning your device is probably a clone and the same as other Trademark Brands like HK1, Bqeel, H96, or Vontar, all of which are made by the same unknown OEM/ODM manufacturer, but I suspect they are all made by Elebao Technology Co.
Only have seen 1 working rom for these devices, and have personally tested it, see this post : https://forum.freaktab.com/forum/tv-..._s905x3-test57
Originally posted by RiCkLaR_atvX View PostTICTID is just a Trademark Brand, meaning your device is probably a clone and the same as other Trademark Brands like HK1, Bqeel, H96, or Vontar, all of which are made by the same unknown OEM/ODM manufacturer, but I suspect they are all made by Elebao Technology Co.
Originally posted by sssolider2 View PostWill do.
I can finally watch my iptv and media without any annoying stock pop ups.
I already love this custom rom within the hour!
Originally posted by ath156 View PostMaybe you can try also my custom rom (https://forum.freaktab.com/forum/tv-...amlogic-s905x3) if your box is the same as in post #3.
I can't try this out because my tictid has some hardware problem. like the screen will change colors, its almost like the hardware can;t keep up with the software. good news, i bought a nividia shield so i have no more problems with android tv stuff
If you mean something like distorted colors (i.e all the screen pinky etc) this might be the problem of an improper bootloader. You might try to load another firmware (the original, a custom rom like mine or another). Anyway its your box and you better know what to do.
i am just going to recycle it. i prefer to use nvidia shield pro tv and firesticks 4k because i do not get any problems with it. i dont have to deal with custom software. besides, i just need like 3 or 4 apps running the most.
There are currently 2706 users online. 0 members and 2706 guests.
