Help needed pls
    Help needed pls
    Hi I'm a newbie and need some guidance pls. I've got an S8 max android tv box running android 9 for the full specs see pics included.
    The problem I have is that some apps in google play store arnt there or say this app isnt compatible with your device, the main one being Netflix, and if i install a Netflix apk it doesnt work properly especially the streaming quality ect and you have to use a air mouse to navigate also my Iptv runs sluggish on this box and I have fiber and get a 72 speed. Any help or guidance would be gratefully appreciated.
    Sent from my SM-G975F using Tapatalk
    perhaps...
    you should apply a cool mod... on the CPU?
    94.6 Celsius seems abit high
    As for Netflix :
    Just buy a : Amazon firstick 4k or nvidia shield TV
    Getting Netflix to run on a non lic Netflix device.. is horror story in the making!
    trust me
    cheers
      What's a cool mod ?
        A coolmod... is when you change the cooling capability of a device
        Most android TV boxes have no Airflow... Some are sold without a (proper) heatsink on the CPU
        If the CPU overheats...then it starts to throttle down ( example from 1.8 GHz to 1 GHz )
        -that's why some people moddify there TV box.. there a bunch of threads/posts on freaktab about this
        --Some add holes to the top of there unit ( so hot air can escape )
        --Some add a nice big proper heatsink on there CPU
        --Some add a ventilator to top of there device
        --Some water cool there CPU ( see rasbberry water coolers ) ( abit of over kill )
        Most devices throttle at 70c...( and your screenshot shows 94c that's impressive )
        -Most device are running stock/iddeling at 60c... because lack of cooling/throttling... the can never run at full speed
        Cheers
