Finally got round to updating to Finless 1.6 and everything is working smoothly.
However, there is one very, annoying thing I'm finding... The status/system bar at the bottom of the screen.
My problem is that I can't get rid of it of the status bar on the home screen. In other apps, it disappears as normal, and I have checked the "auto-hide systembar" option in the settings app.
Another annoying thing, I've repositioned some of my apps at the bottom of the home screen, in the dock. The problem is that, when I'm using the remote's d-pad to navigate, sometimes the app that becomes highlighted is not the one that I want (or would expect) to become highlighted.
Eg. when in the bottom left corrner app is highlighted, one would expect a further "down press" would select the app in on the left side of the dock. Instead, the cursor jumps to the centre "Apps" icon... This makes navigating the dock a nightmare. Is there any way to correct this?
Any help would be greatly appreciated.
Thanks.
