Android 9 partition repack tool!
My vendor image building fails with this message:
Code:create a sparse img... ################## loaded 1266 fs_config entries failed to find [/vendor/etc/init/hw/[p] ap6330] in canned fs_config make: *** [build/mod.mak:62: bc-tool/stamp/.stamp.mod-vendor] Error 1
anyone? i run everything is fine exclude this:
Code:~/afck$ make mod-supersu mkdir -p "bc-tool/stamp" #mkdir -p bc-tool/system/system/system/app/SuperSU #unzip -qojp common/Superuser.apk > bc-tool/system/system/system/app/SuperSU/SuperSU.apk # Пропатчим SuperSU # @echo -e 'Patching APK file bc-tool/system/system/system/app/SuperSU/SuperSU.apk' java -jar tools/apktool_2.4.0.jar decode -o out/amlogic/device/1-2g/patch-SuperSU.apk -f bc-tool/system/system/system/app/SuperSU/SuperSU.apk Input file (bc-tool/system/system/system/app/SuperSU/SuperSU.apk) was not found or was not readable. make: *** [build/mod.mak:62: bc-tool/stamp/.stamp.mod-supersu] Error 1
Code:$ java -version openjdk version "11.0.15" 2022-04-19 OpenJDK Runtime Environment (build 11.0.15+10-Ubuntu-0ubuntu0.22.04.1) OpenJDK 64-Bit Server VM (build 11.0.15+10-Ubuntu-0ubuntu0.22.04.1, mixed mode, sharing) $ sudo apt install python3.10 Reading package lists... Done Building dependency tree... Done Reading state information... Done python3.10 is already the newest version (3.10.4-3). python3.10 set to manually installed. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. $ python3.10 --version Python 3.10.4
Originally posted by bumerc View Post
You need to run the script mentioned above during the initial installation of afck
edit: don't know why, maybe network reason, now it downloading, but some app failed download
and I found a video about this tool, but seem some change ?
Thank Sir!Last edited by oldman20; 18 May 2022, 22:20.
Have you finded out any result of this problem ?
Almost the same problem has happened to me.
And Would you please reupload the bc-tool?
The links are not working now.Thanks.
Originally posted by oldman20 View Postforgive it, i have it now
https://drive.google.com/file/d/18fz...nnGmGcOgv/view
There are currently 1666 users online. 2 members and 1664 guests.
