Android 9 partition repack tool!
Originally posted by ChevChelios3 View PostHi Guys. Can someone who has a clue help me, unpack/edit Android 9 img and pack again, its for Amlogic S905X Device. Everything I've tried so far has failed while packing. I would pay for it too.
thanks.
If I remember correctly S905X boxes are shipped with Android 6 by default. Some boxes have upgraded to android 7, and very few rom builders (e.g.superceleron) attempted to build android 8 or 9 for S905X boxes. So it does surprise me you are having an (assumed working - without hardware issues) android 9 image for your S905X box. Please double check if your image is REALLY android 9. Some of the images are faked to be android 9 but rather being actually an earlier android version.
If your image is indeed android 9, you need to have a Linux machine (can be a virtual machine via VMware or similar) and follow the instruction on the first post of this thread.
If your android version is actually 8 or below, please use Ricky's amlogic tools instead. You can find it here: (credit: ricky divjakovski )
You do need to disable your antivirus before running his tool. Don't worry, it's a legit tool.
By the way, we don't charge for helping each other. This is a free community.
Originally posted by thanghn90 View Post
You need to be more specific. Do you have the link to the android 9 img? What is exactly the model of your box? And most importantly, what is exactly the error you get? (e.g. bootloop while burning? error repacking? bricked device?)
And ye i did fix all issues with it, i even done a android 10 for the s905x.. but that is another story lol.
Anyway Khadas V1 is s905x and has Android 9, even its sdk is public to anyone who wants it to port it to a more generic s905x.
I'm trying to unpack an Android 10 S905X4 based image but when I run 'make mod-unpack' it gives the following error:
Code:rm -rf "out/amlogic/device/1-2g/img-ubt/odm" mkdir -p "out/amlogic/device/1-2g/img-ubt/odm" tools/linux/ext4unpack out/amlogic/device/1-2g/img-unpack/odm.PARTITION out/amlogic/device/1-2g/img-ubt/odm od: out/amlogic/device/1-2g/img-unpack/odm.PARTITION: No such file or directory build/amlogic/device/20-unpack/unpack.mak:7: recipe for target 'out/amlogic/device/1-2g/img-ubt/.stamp.unpack-odm' failed make: *** [out/amlogic/device/1-2g/img-ubt/.stamp.unpack-odm] Error 1
Any idea what the issue is? Possibly an encrypted img?
It's a Mecool KM6 Deluxe. Here's the upgrade package: https://mega.nz/file/aQpg2YKI#EMzS4O...f7jJb6hkg1ThTULast edited by atvbca; 07-16-2021, 03:18.
superceleron Can upgrade package image files be locked so that they can't be unpacked or likely just a limitation of the unpacker?
Originally posted by atvbca View PostI'm trying to unpack an Android 10 S905X4 based image but when I run 'make mod-unpack' it gives the following error:
sagert I found XVortex kitchen but it can't unpack the super.img. Do you know any tool for that?
I found lpunpack which is supposed to unpack super.img in raw format but I don't know how to compile it and there are no instructions. https://android.googlesource.com/pla...rtition_tools/Last edited by atvbca; 07-16-2021, 23:10.
Originally posted by atvbca View Postsagert I found XVortex kitchen but it can't unpack the super.img. Do you know any tool for that?
Originally posted by Borec1 View PostI unpacked my ROM and I have some RAW files that I can edit. But I would like to change the main logo of the bootloader how can I do it?
unpack
Code:logo_img_packer -d logo.PARTITION ~/logo
Code:logo_img_packer -r ~/logo new_logo.PARTITION
im getting a few errors not sure if it effects anything as the img does rebuild without error but not tried burning yet
/home/osboxes/afck/bc-tool/test/gen_perms_caps_labels_stock.sh out/amlogic/device/1-2g/img-unpack/vendor.PARTITION
convert to unsparse...
Invalid sparse file format at header magi
Failed to read sparse file
mount unsparseimg...
mount: /home/osboxes/afck/bc-tool/test/vendor.PARTITION: wrong fs type, bad option, bad superblock on /dev/loop14, missing codepage or helper program, or other error.
dump vendor.PARTITION filesystem...
find: getfilecon failed: ‘vendor.PARTITION’: No data available
umount: vendor.PARTITION: not mounted.
ok!
/home/osboxes/afck/bc-tool/test/gen_perms_caps_labels_stock.sh out/amlogic/device/1-2g/img-unpack/product.PARTITION
mount: /home/osboxes/afck/bc-tool/test/product.PARTITION: wrong fs type, bad option, bad superblock on /dev/loop14, missing codepage or helper program, or other error.
dump product.PARTITION filesystem...
find: getfilecon failed: ‘product.PARTITION’: No data available
umount: product.PARTITION: not mounted.
ok!
/home/osboxes/afck/bc-tool/test/gen_perms_caps_labels_stock.sh out/amlogic/device/1-2g/img-unpack/system.PARTITION
mount: /home/osboxes/afck/bc-tool/test/system.PARTITION: wrong fs type, bad option, bad superblock on /dev/loop14, missing codepage or helper program, or other error.
dump system.PARTITION filesystem...
find: getfilecon failed: ‘system.PARTITION’: No data available
umount: system.PARTITION: not mounted.
ok!
There are currently 8532 users online. 5 members and 8527 guests.
