MECOOL KM1 Google Certified Amlogic S905X3 2GB/16GB Android 9.0 TV BOX
2.4G+5G WIFI Bluetooth USB3.0 Built-in Chromecast with
On Key To Start YouTube Prime Video Google Play Google Assistant - Black
Highlights as found:
The MECOOL KM1 android set-top box is one of the best in its price segment of TV boxes, which has a working certification from Google.
It is equipped with the AMlogic S905X3 SoC CPU which is a Quad Core manufactured in 12nm that reaches up to 1.9 GHz speed and integrates a Mali-G31 MP2 GPU.
This chip has 4 ARM Cortex-A55 CPU cores and also an NPU for iA. The VPU is an Amlogic Video Engine 10 with support Dolby Vision HDR, HDR10+, HDR10, HLG and PRIME HDR among others.
This Box has 3 variants, 2GB/16GB, 4GB/32GB and 4GB/16GB, the eMMc storage memory can be expanded from the microSD card reader included on one side of the quadrangular box.
It is based on the latest Android 9.0 OS, with high speed and smooth performance, which is designed to turn your regular TV into a smart one.
At the level of wireless connectivity, it has integrated in Dual Band Wifi aC board with internal antenna and Bluetooth 4.2.
The connectors included in the plastic box are few, only a USB 2.0 port, another USB 3.0, a 10/100 Ethernet connector, an HDMI 2.1 video output and a connector for analog audio and video out
Let's have a look see at what we have:
The Box:
What's in the Box:
Ports to be seen:
Remove the Lid:
Out with the PCB:
Few things worth noting:
Mediatek Wifi Chips
3 x WiFi/BT Antennae
Roadwell Ram, sounds a bit Mad Max to me.
Reset button can be seen behind AV port.
Many reviews around of this beasty presently
More a bit later
Geekbuying
More Discussion can be found;
https://forum.freaktab.com/forum/tv-...287#post804287 < click
