H96 Max RK3318 Android 10
I have a Transpeed TR99 mini+ Android 9 4g/32g. I bought it last year and wanted to upgrade it to Android 10 today. I used the ROM/firmware from this post and it broke the wifi. I thought it maybe a corrupt download, so I did it again and same result. I found a more recent ROM on the H96 website and it fixed my issue with the wifi. I haven't tested all aspects of this ROM yet, but what I have works as it should. The link for the H96 ROM is first and the second is the HK1 ROM you were looking for. I downloaded it to try if the H96 ROM failed.
NOTE! These are not my links or ROMs. I am just providing the links.
Sent from my SM-G975U using Tapatalk
Hi, i have the HK1 Rbox with Android 10. I have rooted my Box with the Tutorial from widi23*
*I had the same problems with the wifi> no connection. But with my instructions it now works wonderfully because I now have the correct boot.img on the TV box.
Here is my Solution:
What u need to root ur Tv Box ...
- Android Tool v2.3 for Windows (no driver needed)
- Firmware Image from your Tv Box (example : RK 3318) search by Google
- Smartphone or other Android* device with Magisk Manager App (no root is needed) *Tv Box is to slow
First:
Install the Magisk Manager App on your Tv Box and Smartphone. (https://magiskmanager.com)
What now?
1. Extract and start the Android Tool on ur PC
2. Go to "Advanced Function"
3. Go to " Firmware " >> " ... " and load*(*waiting) ur TV Box Image * (.img not .img.7z* *unzip)
4. Click on "Unpack" the to extract the Image now.
5. In the same Folder with the Android Tool u have the Folder "Output", the extrated Image is here.
6. Now go to "Output" > "Android" > "Image" here is the "boot.img", this is what we needed
7. Copy the "boot.img" to the Device with the Magisk Manager App (example: Smartphone)
8. Start the Magisk Manager and click on Magisk install > Select and patch a file > boot.img (wait)
9. The patched boot.img* is in the Download folder from ur Device. (*has a different name magisk_patched_xxx.img after patching, calls it boot.img again)
10. Copy the patched boot.img to ur TV Box (example: USB Stick)
11. U need Developer settings on ur Tv Box. ( no Developer? go to "About" > "Build" > on ur Remote 5x "Ok Button" > done)
12.Go to the "Developer settings" > "Select Image to Flash" > "patched boot.img" > select "boot" > done
13.Restart ur Tv Box > finisch u have now root.
everyone is responsible for himself and his actions. I am not responsible for any damage
Here is the finished patched boot.img for HK1 Rbox and other *Tv Box's with RK3318. *It may be that this does not work properly with other devices
Android 11 ROM without Root, has tested and works for the box
https://androidtvbox.eu/h96-max-v11-...-soc-20210510/
Originally posted by HiTony View PostAndroid 11 ROM without Root, has tested and works for the box
no root. is there a way to root?
Originally posted by Nemo17 View PostUSB does not update itself either, has to pull the plug from the hdd every time :-(
mirofon no function (YouTube)
I'm still looking for root with TRWP or magisks for android 11 version instaler on my H96max 4k RK3318
Try to give a more detailed explanation to your USB problem thank you
There are currently 1643 users online. 1 members and 1642 guests.
