H96 Max RK3318 Android 10
My TV Box is H96 Max Plus 4 / 64gb RK3328.
But I Flash with Firmware H96 Max RK3318 Android 10, and the result is very good, everything works normally,
not only flash and I have also succeeded in Root Firnware H96 max rk3318 Android 10 with Magisk.
Here I will tell you how to Root H96 max Android 10 with Magisk.
You download the material first, click the link below.
After downloading you extract the file, there are two files, you install the Magisk manager apk, then you just move magisk_patched.img to the storage sdcard / Download / ....
Now it's up to you Execution ...
Go to Settings then scroll to Device Preferences then you scroll again to Developer Options, scroll again to (Go to loader) click "Select Image to Flash Dengerous: This operation can cause system instability"
There you just need to point to the file "magisk_patched.img", then there are several options, you select the "boot" then click OK.
Wait a few seconds until finished Flash.
Finally, you just need to reboot the device.
After the device turns back on, then Open Magisk Manager, which was already installed.
And Taraaaa .... It worked !!!
Link ;
https://mega.nz/file/hvYhSCAZ#gSrEde...hg-md8onMertDg
Originally posted by lucaslks View Postcan you help me where i find firmware 7.1 or 8.1 for H96 Max Rk3318? because I want to use Hijack and it is not compatible with recent Android.
Link ;
Originally posted by manu_manu4 View PostThe box is now with Android 10
Nur US$51.96, kaufen Sie den besten H96 MAX RK3318 4GB RAM 32GB ROM 5G WIFI Bluetooth 4.0 Android 10.0 4K VP9 H.265 TV Box Unterstützung Youtube 4K Online-Shop zum Großhandelspreis.
I found the firmware in 4PDA
https://drive.google.com/drive/folde...ToCAWftFgAWLJb
Originally posted by catalaman View Post
hello my friend i did the update of rk3318 but i lost the wifi connect help plz
Note: if your rooting make sure and install Magisk manager first then use that to make your boot.img then after you flash reboot.
Sent from my moto g(8) power using Tapatalk
Link ;
There are currently 2596 users online. 0 members and 2596 guests.
