Thank you for your help. But unfortunately I was unsuccessful. I believe I will have to throw it in the trash.
R98 - RK3318 - I'm looking for compatible firmware.
Good afternoon everyone
one more novelty for this YOUIT R98 box
Android 11
Rom H96 Max V11
with everything working dual band AC 5.8 GHZ wifi
Bluetooth
everything perfect
Root - no
link https://drive.google.com/file/d/1322...QskaI7hyg/view
https://drive.google.com/file/d/1rOkctDKLM9wJNAA_uxCGY10OtTPPjVT6/edit
Android 11
Rom HK1 Series (HK1_Super)
Bluetooth
everything perfect
Root - yes
link https://drive.google.com/file/d/1j7D...9DeEEBe3T/viewLast edited by bruski; 09-22-2021, 00:33.
insist
change usb cable reverse tip
test another usb port
It's impossible not to work
if the card doesn't have a short
insist
fast usb stick several times
uninstall tool driver and reinstall
Good afternoon , I recently had a rk3228 board with blue led and nothing recovered not even the short on the board revived solution , I created a 4 gigs SDcard HC 1 CLASS 6 with native image rebuilt bootlouder then revived the box and continue to update with custom rom, its only output """
Greetings to everyone!
I replaced my Alfawise S92 after about 5 years with H96 Max V11 (RK3318, 4GB RAM, 32GB storage). Only issue with Android 11 firmware from last year is that says on cpu-z that the full resolution is only 1280x720, whatever resolution I choose.
I'm thinking to use the rooted rom of the similar device, the issue with the resolution will be still present with newer firmware?
The RAM speed of RK3318 is not even fast enough to support HDR or 4K video properly.
RK3318 is a low cost clone of RK3328 used mainly for 720p/upscaled 1080p video playback.
Android 11
Rom H96 Max V11
Bluetooth
everything perfect
Root - no
Android 11
Bluetooth
everything perfect
Root - yes
thank somuch
my box wifi SP8330 can install your rom??
thank somuch
There are currently 1929 users online. 6 members and 1923 guests.
