[ROM] Spartan_ROM ATV S905X3
    Originally posted by hannah View Post
    minixfreak
    Step 1. This is to report that GT1_MINI2.img failed to install via USB Burning Tool. Stops at 4%.
    Step 2. Extracted the vendor.partition from this ROM, replaced and then repacked SLIMBOX-ATV-TX3-QZ-ver7.1 with AMlogic Tools [6.0.0]
    Step 3. Flashed with USB Burning Tool was successful but box reboots to Android Recovery.
    Steps 4. Reflashed SLIMBOX ROM again.
    My TV Box: Tanix TX3 4GB,32GB Amlogic S905X3 2.4G/5GHz Dual Wifi BT 4.2 QZ High-Resolution PCB Picture: https://ibb.co/zbqW5HH Details from PCB: CS_905X3_TX95_B4_QZ_V1.2 (So this a QZ version of the Board) WIFI Chip: SP6330 ZX190906 I flashed this SLIMBOX ATV9 ROM (QZ version) Clock LED, IR Remote, BlueTooth, Lan, Wifi
    Hannah
    I had these 2 problems. Reflash/burn stock firmware. Then use this image on amlogic burn tool make sure to untick erase bootloader
      Also select erase all
        Don't suppose anyone can advise if multichannel 5.1 PCM (LPCM) works on this ROM?
        My stock X96 AIR is only giving me 2.0 LPCM.
        Please note this is not related to compressed formats such as Dolby Digital or DTS etc as i know bitstreaming those formats generally works fine.
          Hi guys, gave two tries to flash this ROM
          Each time over working stock firmware(GT1mini-2_v204P0_20200316).
          1st time with Erase flash(Normal erase) and with Erase bootloader
          2nd with Erase flash(Erase all) and without Erase bootloader
          Both times after first load (like 5 minutes) it goes to twrp.
          Is there some full instruction? Or help me to understand what is going wrong.
          Thanks in advance!
            Thanks in advance!
            i dunno theres something wrong thats for sure
              Hello.
              This rom is suitable for Mecool KM1?
                Originally posted by nasosto View Post
                Hello.
                it might work but remote wont since its based on beelink devices .... i personally havent tried it so everything will always be at your own risk
                  Will any of these work on the X96 Air P3?
                    all i can say i built for beelink devices but you can try if you want .... if i had the actually boxes you are talking about i would for sure get it working for you but i dont ....
                      EACHLINK X3 mini? Spartan rom working with this device? Same CPU, S905X3 Many thx.
                        mmh kind of weired did you minixfreak take off the S905x3 builds?
                        May I ask wether there is an x96 max+ 4/32 build?
                          ill be working on s905x3 when i get time just focused on s922x perfecting it
                            Ah, ok, no problem, just didnt know if there are any
                              For x96 max plus 4gb there is a lot of firmware in this topic:
                                https://4pda.ru/forum/index.php?showtopic=1002233
                                thanks, I know, but I will receive x96 AIR and MINIXFREAK offers best wifi!
