Why was the SLIMBOX ROM Deleted?
Originally posted by BowerR64 View PostIs it for the N5 max?
I wanted to try it but i cant find any links to download it that work.
Ive tried twice to download it from that crap site its uploaded to and after 2 hours the DL fails
So is this not the right thread?
https://forum.freaktab.com/forum/tv-...max#post787465
Tell me which link works i couldnt get either to work
Originally posted by hjpca View Post1 of the best roms i have tested works awesome on f3 air box.how do i get rid of ota update error
Originally posted by RiCkLaR_atvX View Post
If the error is caused by the OTA_Update.apk then just disable it; or if the Error keeps getting generated in a Heads-Up Pop-Up Window it may be due to Google.Play.Services which you can go in settings and turn-Off notifications from Play.Services system app.
Originally posted by kancrutt View Postanyone has TWRP AML SlimHouse 3.4.0.zip from SlimBox thread at 4PDA?
There are currently 1984 users online. 2 members and 1982 guests.
