Why was the SLIMBOX ROM Deleted?
I haven't tried the other versions, but first impressions of version 7 is that this guy has made a great ROM! Of course I've only just installed the ROM and added a full suite of apps, am using the H96_Max_X3 rom on my Vontar X3 and everything is looking good. The one thing I had to do immediately was install CoreELEC and add their bootloader blob to correct the Sleep/CEC functions, otherwise couldn't leave the device plugged in or it wouldn't stay off while using different devices on the same TV.
Originally posted by RiCkLaR_atvX View PostI haven't tried the other versions, but first impressions of version 7 is that this guy has made a great ROM! Of course I've only just installed the ROM and added a full suite of apps, am using the H96_Max_X3 rom on my Vontar X3 and everything is looking good. The one thing I had to do immediately was install CoreELEC and add their bootloader blob to correct the Sleep/CEC functions, otherwise couldn't leave the device plugged in or it wouldn't stay off while using different devices on the same TV.
But for me one of the best roms is the Malay Mod (permanent Magisk, TWRP, ViperFandroid, init.d capable etc).
Originally posted by RiCkLaR_atvX View Postlol, it happens, the anti-spam bot is aggressive on this forum
You can download it from here https://yadi.sk/d/GWW_dL7anKvorA. The only problem is that it starts in Russian and you have to change the language "blindly" (I guess you can do it the way I first dit it). It is AOSP version. Based on this custom rom I have made one of my own where I added:
- In settings I added the choice to enable upper Bar / Status Bar (where you choose if you want to show IP, Mac address, CPU temp, CPU load, CPU freq. etc)
- Choice to enable lower Bar / Navigation Bar
- 2 preinstalled applications which are best (in my opinion) for Notification and Navigation Bars. You can use these at the same time as the above ones (although I do not recommend it).
- Other changes in apps which I think improve the rom (e.g I deleted some preinstalled roms of russian interest, I corrected the ENTER bug when using an external keyboard etc)
The only problem is that I have made this rom to start by default in my language but if you are interested I can easily made it to start in English.
edit: And here is a link of a previous discussion about it here in Freaktab https://forum.freaktab.com/forum/tv-...905x3-by-malay (although I have used it from almost the first days of its release).
edit2: The above was marked as "potential spam" .................................................. ....
Originally posted by ath156 View PostThe only problem is that it starts in Russian...
Originally posted by RiCkLaR_atvX View PostSo it is Russian made ROM, you found on 4pda? Correct?
Um that freaktab link didn't work.
*ttps://forum.freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s905x3/firmware-roms-tools-ds/803963-rom-mod-hk1-box-vontar-x3-bqeel-y8-max-transpeed-x3-air-%C2%A0amlogic-s905x3-by-malay Try this (*=h)
There are currently 2535 users online. 5 members and 2530 guests.
