leolas
New custom kernels for imito QX1
Originally posted by PolloLoco View Post
Originally posted by leolas View PostIt works great at 1080p so never use 720p only to test they works, the result must be like 1500 points up with antutu, but I am not sure because I didnt use them for a long time.
leolas
Originally posted by PolloLoco View PostThanks. I'm curious, if only because I'd like a little more performance in emulators. If I get bored, I'll quickflash an OC'ed 720P rom and report back.
Just to ensure that I didn't make a mistake quickflashing, I repeated the process twice. Quickflashing is almost too easy . . . it feels like cheating.
Originally posted by PolloLoco View PostWell Leolas, I tried it this morning. When I quickflashed the OC'ed 720P kernel and then ran Antutu - the result was a score increase of only 600, to 21,200. HOWEVER, Antutu is reporting that the stick is still processing at 1080P. Any idea why that happens? Is there any other way to verify that the kernel is 720P or 1080P?
Originally posted by rdsok View PostDouble check that you got the kernel that was a 720p one and not one that OC'd the DDR memory to 720
Is there a step needed before quickflashing to make sure the kernel installs correctly? I might try another 720p kernel just to make sure its not isolated to this one.
Re: New custom kernels for imito QX1
Originally posted by PolloLoco View PostI just double checked. It's 720p, cpu1800h, ddr800, gpu798.
Leolas.
Sent by my phone.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostOut of home for weekend, on Monday I will try to check.
Leolas.
Sent by my phone.
When I was running leolas' 1.5a ROM for the QX1 ( which I think has the same kernels as this has )... I didn't use Quickflash to flash them... I used his CWM framework to make a set of kernels that would flash from CWM and I did test a couple of the 720p ROM's before I switched up to the 1080p ones... These worked fine using that method to flash with.
When I had installed the Quickshot v2 ROM... I simply used the prebuilt kernels that are listed in that thread to Quickflash with... Again, those kernels flashed perfectly fine but I can't recall if I tested any of the 720p versions. It was about that timeframe that my QX1 started to fail and I have since returned it for refund.
So as a suggestion... if leolas can recall the link to the CWM framework ( I couldn't find it this morning )... perhaps that is another direction to try.
I finally found the instructions that leolas posted about making a CWM flashable zip file ( the framework I mentioned )... see Some cmw installable zips
The process is very simple for most to follow.
Originally posted by rdsok View PostI finally found the instructions that leolas posted about making a CWM flashable zip file ( the framework I mentioned )... see Some cmw installable zips
Originally posted by PolloLoco View PostThanks! But to be honest, I am more interested in finding out why quickflash does or doesn't work.
Originally posted by rdsok View PostI know it works with the kernels that Quickshot v2 uses/comes with ... so perhaps its the specific kernels you've chosen to test with or the ROM you are trying it with...
Originally posted by PolloLoco View PostI'm using the quickshot v2 rom, and the kernels it comes with. So that's not it.
Originally posted by rdsok View PostAhh... then you should have posted in that thread, not this one which were for earlier kernels that leolas had made... but, as I mentioned, I didn't have a problem on QS v2 when I had mine...
There are currently 3414 users online. 0 members and 3414 guests.
