Reliable firmware - where to find??
Originally posted by Silver View PostHow about you get a good box like from ugoos.com? they are great, we have to boycott the chinese clone manufacturers so they put more work and support in their devices.
Dont buy the cheap boxes.
Originally posted by neilop View Post
Just got it from Amazon a few years ago. Just trying to getting working a little better. If I'd have know about all this back then, may be I would have. If I was to buy anything, I'd probably get a fire stick as they will do everything I need.
Here it that modified firmware, first attempt at porting to another base, may not work but let me know how it went and can see of can figure out where its gone wrong )
REMOVED LINK (BROKEN)
it flashed to my 1gb box but appears to be stuck on the boot animation, but now i know it will actually flash on my box i have somthing to test it on (Thought i would have to rely on you flashing to even to test seems i can install it though)Last edited by aidanmacgregor; 12 June 2020, 20:08.
Many thanks :-)
Originally posted by aidanmacgregor View Post
i did reply this morning but its marked as pending approval, i did put a link up but it most lightly wont work have managed to flash the rom you sent onto my 1gb box to test, seem to have run into an issue where i cant change anything without the image failing to burn at 98% not sure why but am trying to figure it our
Ok thanks. Why does it do that? I get that quite a lot on here. I'm at the stage now where I have tried everything. I now even can't put the working img back on to the box fails at 7% slowly going crazy! Thanks for your help.
Because i edited it twice, it automatically got marked as needing approval, thes boxes can be very frustrating, they require so much effort just to get them to work sometimes, hopefully you can get somthing flashe on it again but not a good sign that you cant flash a previosly working ROM, you could try "force erase all" have f funny feeling i had to do that once to get around an issue (Was long time ago so cant remember specifics & Why)
Some progress. I managed to get your img on to a box (one does seem permanently bricked. Can’t get anything on to it). However, it won’t load, screen flashes up Android TV With your name and boxes resets and it loops continually. Some slight progress!
haha yhea little bit of progress at least 1 not bricked, was it the original or the (VERY probably broken) version i posed a few comments ago? im not sure about what to try next, i have asked about not being able to edit the image you sent me (my suspicion is maybe SElinux)
Version 7 FINAL Aidan's Custom Android TV Rom (7.1.2) v6.17 build.prop net tweaks more wifi drivers miracast 320DPI.img
There are currently 1617 users online. 3 members and 1614 guests.
