[ROM] X96-Air hybrid Clean AOSP
    hi All ,i like to share my custom rom, i made it for my X96 Air box,
    this is clean rom so its content very basic uses, any other apps like kodi can download directly from market
    - base on X96 stock rom
    - latest ATV Google APPs
    - hybrid home, easy switch between ATV home and Non ATV Home
    - easy direct access ATV app from Non ATV Home
    - LiveWallpaper enabled
    - Upgraded Wifi driver from latest OTA update
    - remove all unnecessary app from stock rom
    - VFX enable are use ( from SlimHouse)
    - Home Switcher Support Home from
    • Jesonkung
    • Xperia
    - and others
    update 20200616:
    - sound
    - settings
    update i mistakenly upload broken update 20200616, now its fixed,
    Code:
    // File Checksum Integrity Verifier version 2.05.
    4b5e45b11992d909d9e4b839ea391d0b bullghost-x96air-20200616-signed.zip
    for updating from previous one, just need flash and clear /wipe the cache only,
    for fresh install need to wipe data and cache.
    i like to thanks to our master here, that already help me alot to learn many new things from their contribution
    - superceleron
    - slimhouse (many inspire thing i have learn from his custom rom)
    - minifreak
    - magendanz
    Rom:
    https://sourceforge.net/projects/bul...files/release/
    You may only view thumbnails in this gallery. This gallery has 6 photos.
    Not bad for first firmware. Some bugs:
    1. The +5V on USB port does not turn off in sleep mode. Its not good for me since I use a fan for cooling, and this fan powered by usb.
    2. Mouse scroll wheel is incorrect in some apps. I spin the wheel, and screen as if refreshes and again returns to the top of the page. Because of this,its impossible to move the cursor to the desired position.
    P.S. In general - this is not hybrid rom, not clear AOSP, this is usual android tv(with castrated playmarket) with two pre-installed launchers.
    P.P.S. Sorry for my bad english
      @digitalriver digitalriver
      yeah from first time i use this box, it quit hot, need some cooling, like passive cooling using extra heatsink or using fan, i think the box design is not good there is no ventilation for air flow
        reupload update
          Any tutorial how to flash it ? Also I can't see the pictures that you uploaded of the rom...
