"You have to press Start/Run in Amlogic burning tool then hold the reset button, connect the USB cable and then connect the power"
On two different PC's but the device is never detected. I connected HDMI and saw that I am in recovery mode but still my PC doesn't see it.
Not sure what to do. The device is working fine with stock Android Pie, trying to go dual boot.
