TUREWELL T95 Max+ wake up bug and hardware keyboard
I have T95 max+ 4/64G box and it keeps waking up on its own. I had CEC enabled which was a nightmare and I disabled it but still having issues waking up. I also have a H/W keyboard which I used with an older M8S fine but with this one sometimes it refuses to write unless I start by typing on the on screen keyboard. I also noticed its wired Ethernet is too slow when am playing UHD movies on the LAN (from a Samba share)Tags: None
I have an issue with HDMI-CEC too, where sometimes it never wakes when I turn on TV, very random. I have to pull the plug to reboot it.
I flashed the android TV Rom on here and still same issue.
Wish there was a way to disable HDMI-CEC power only! Someone must have a hack/method to disable the power/sleep feature of HDMI-CEC only??
I have tried all the one key power options in android settings and all the same. And it’s 100% the box as my other device turns on every time via HDMI-CEC.
The issues I have are with the box and it waking up, not my TV. Think this box just has an issue with sleeping and waking full stop. I use HDMI-CEC so can’t really turn it off completely, just wanted to somehow disable it going to sleep when I turn my TV off, keeping it on permanently. Not found a solution yet!
Originally posted by Bond02 View Post
Which one?
I disabled CEC so no issues with the TV but the box randomly turns on
https://forum.freaktab.com/forum/tv-...674#post799674
Way better than the original stock rom. I’ve disabled the ATV launcher though and used my own home launcher.
Terrible HDMI-CEC operation is usually due to a faulty bootloader, and this why everybody always recommends for people to purchase devices that have after-sale Software Support, not devices that are "Ship-and-Forget" like all these different T95 models. Usually is best to buy Beelink, Minix, or Ugoos -- those 3 brands do try to improve their devices with some after-sales software support, I know everybody want to save a dollar and they end up buying the cheapest shite available.
The best FIX (my recommendation) is to make your device a Kodi-only box and install CoreELEC software, if your T95 manufacturer didn't encrypt the bootloader then CoreELEC nightly software has a fix for the bootloader to WakeUp/Sleep/PowerOn/Off -- the fix doesn't fix Android, it fixes bootloader for smooth CE operation.
Link to topic on CE bl301 fix: https://discourse.coreelec.org/t/bl3...lems-help/6458
There are currently 2985 users online. 2 members and 2983 guests.
