When I plug in a power cable, there are no LEDs, unless I also plug in the HDMI, then the optical port lights up. Connecting the box to a computer with a USB A to A cable causes it to light up, and is detected by the computer as a 'WorldCup Device'. I have tried to flash stock? firmware from https://androidtvbox.eu/new-firmware...s905x-release/ using the Amlogic USB Burning Tool, but I get an error at 7%:
[14:04:50 592][HUB5-2][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#6&307d5fe6&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x0000074c [14:04:55 662][HUB5-2][Inf]--0-7-0-16 [14:04:55 662][HUB5-2][Inf]--CheckFileRunState succeed [14:04:55 662][HUB5-2][Inf]-- low_power [14:04:55 662][HUB5-2][Inf]--Send command success [14:04:55 662][HUB5-2][Inf]--Read command status success [14:04:55 662][HUB5-2][Inf]-------------Download meson1.dtb----------- [14:04:55 662][HUB5-2][Inf]--0-7-0-16 [14:04:55 662][HUB5-2][Inf]-- download mem dtb normal 79872 [14:04:55 662][HUB5-2][Inf]--Send download command success [14:04:55 677][HUB5-2][Inf]--Read command status success [14:04:55 693][HUB5-2][Inf]--Transfer complete [14:04:55 693][HUB5-2][Inf]--Send download get_status command succeed [14:04:55 693][HUB5-2][Inf]--get_status success [14:04:56 210][HUB5-2][Inf]-------------ERASE FLASH----------- [14:04:56 210][HUB5-2][Inf]--disk_initial 1 [14:04:56 210][HUB5-2][Inf]--Send command success [14:04:56 569][HUB5-2][Err]--failed:[14:04:56 569][HUB5-2][Err]--Check command return failed [14:04:56 600][HUB5-2][Err]--[0x30201004]UBOOT/Disk initialize/Send command/Error result [14:04:56 600][HUB5-2][Inf]--Close device handle 0x0000074c
