Question about the limitations of Android
.Well with CoreElec my drive troubes are gone and I have it even bootein from a Sandisk Ultra Fit (tiny and fast 140/50) in the same usb3 hub also the box rund 10C 20F cooler and I have no unwanted android akitivity in the background.
BUT needing a second computer to execute commands is kind of stupid and gives me trouble, I wanted to make it dual boot and copy the CoreElec on the internal memory but one CE guy was not helpful at all.
Originally posted by x96maxplus View Post.Well with CoreElec my drive troubes are gone and I have it even bootein from a Sandisk Ultra Fit (tiny and fast 140/50) in the same usb3 hub also the box rund 10C 20F cooler and I have no unwanted android akitivity in the background.
Originally posted by x96maxplus View PostNo officially only 2 devices but it works for most devices and it worked for somebody with a x96 max+
Sadly most people do not have the courtesy to post a step by step with the correct links when the got it working.
https://androidpctv.com/tutorial-lib...v-box-android/
https://discourse.coreelec.org/t/how...emmc-tool/7630
The first link is no good as they have changed installtointeral to ceemmc -x then option 3. I have installed it on my GT King and it is 100% working. It takes seconds and is very easy.Last edited by Charlie_Boy; 26 August 2020, 15:05.
Thanks CB, but I can not make a connection via the router with ssh or samba and when I use putty just the green cursor is in the corner and it breaks up after 10 sec because it can not find the box.
I read that if Samba andd ssh is not activated during install you cannot reactivate them later even if it is shown. I might follow this line and might to reinstall again...
Is ther by any cance a versionout what can do it without the help of a second computer? Other than a full installation?
Originally posted by x96maxplus View PostThanks CB, but I can not make a connection via the router with ssh or samba and when I use putty just the green cursor is in the corner and it breaks up after 10 sec because it can not find the box.
Originally posted by freddy View PostWhy not have both
No need to write to internal
Defeats the purpose of testing other OS
Any box can be Dual Boot
Simply remove SD Card
Voila back to Andriod
Does not GT KIng have Coreelec preinstalled?
With switch to Partition
If you have use for Android then use it, if not as in my case it makes sense to dump it entirely. I've never been happier.
There are currently 2041 users online. 0 members and 2041 guests.
