The place to find Roms for Clone devices...
Cosmi this link points to post that contain a rom with a date "20190722" which i read to contain multiple wifi-bt combinations. Thank you, i was looking for this. and it will be the next rom that i will try and hope to see a working wifi-bt..
freddy the date on the pcbof the Tanix box i have has a date "20191017.L4" which is newer than the fw that i am about to install but it s my best shot at this.
ps:Man the Phoenixsuit program is such a mess, i will be amazed if things go as well as they did last time.
Update:
By installing the 20190722 dated rom, i finally managed to get the wifi and BT working again! Thanks to the generous efforts, i am now back at where i started.
Now i am wondering if i can find a better version as this build is very sluggish and buggy.
CPU still @ limited to 1480mhz max and usually 400-800 range
The mourse cursor does not click where its suppsed to.
There is always something tickling the CPU or GPU so that i skips that frame here and there.
The frigging Alice UX and its mind boggling "notification system"
Besides the CPUz is reporting a miles different hardware than a H6 cpu.
what would you suggest for this box? should i continue hunting for a better firmware with working wifi-bt?Last edited by I3ordo; 13 September 2020, 18:15.
Excellent find I3ordo
The Date is very important when sourcing Factory Firmware
It is most common for ROM to predate board
Unless was released updated same time as production
Always try to come as close to board as possible.
3 months difference very good chance that was firmware for you.
Unless C Gadgets/ or other has closer/exact date
At least you are up n running !!!!
Agree Alice UX......
Needs improvement
Happy Testing
Cosmi Tired the pendoo and something strange happened... it booted with a pendoo logo and start up fine then the wifi got connected , the system info was changed, the android system info was saying x6 pro or something like that, so the new firmware was replaced as expected but every app that i previously installed including tthe wifi password was there. soo did i just do a partial firmware flashing?
every app and password was still on the box, should they all be wiped while installing the new pendoo version?
also the pendoo version is no different, and actually worse, youtube was not working correctly, not launching videos, netflix had choppy playback as usual and and the box was still being reported as an arm cpu a5 1.48ghz ...
gonna revert back to the 20190722 fw from tanix .
One last effort, i just want to load an android 7.0 fw with "SP6330 wifi/BT combo chip" support. how do we search for such info...?
Update:
Guys, this crappy tanix tx wanna be box is benching like a box from 2008.
here the geekbench score it gets on a fresh fw from Pendoo fw (LC-X6PRO-4Gddr-20190819) and Tanix Fw (H6_9_4Gddr_20190722)
however a normal tx6 should score somethin like 4 times more of this
Tanix TX6 TV Box Allwinner H6 4GB DDR3 + 32GB EMMC 2.4GHz + 5GHz WiFi BT4.1 or 5 Support 4K H.265 Click image for larger versionName: 20181112135631_73499.jpgViews: 1Size: 67.7 KBID: 751596 Main Features ● Android 7.1 operation system ● Allwinner H6 CPU, up to 1.5GHz, Quad core, ARM Cortex-A53 ● Mali T720
I don't know if wi-fi will work!!
Yesterday, i installed these rooms for Tanix Tx6 and added comments to each....
Code:20190722-H6_9_4Gddr_20190722 - tanix logo - And9 -working wifi - video very Jerky.img Pendoo_x6_pro_4GB_Allwinner_H6_20190819_AndroidPC - LC-X6PRO-4Gddr-20190819 - working wifi bt - video very jerky.img Transpeed_6K_H6_4_648M_20191118_1809 - and 9 - working wifi bt - video very jerky.img Sunvell_boot_pac kage_fex_mod - and 8.1 - no bt wifi - jerky.img Tanix_TX6-SCV1 - and7 no wifi - jerky.img TX6_release_H6_7.0_20181219 - android 7 - smooth no wifi bt.img TX6_TANIX_H6_7.0_20181222 - and7 no wifi - less jerky.img TANIX-TX6_H6_7.0_20190123 - And 7 - no wifi jerky.img Tanix_H6_4Gddr_8822bs_20190228 - And 9 - no wifi - jerky playback.img TX6_H6_9_4Gddr_8822bs_20190228.img Tanix_H6_4Gddr_8822bs_20190323 - and9 no wifi - jerky.img H6_7.0_3Gddr_LAGD_20190718 - no wifi portugese.img
Mainly the problem about the box is , it s tendency to skip frames here and there..As if it has a DPC latency issue that we get on windows pc's...
EVREKA!
Found a rom that works beatufully, everything works as it should.
Android 7 fw, custom and clean.
It s a t95MAX rom,
BT / WIFI works
BT can connect to a dualshock 4, normally none of the working fws could pair with that.
No frame drops, judder.
Downside: System is 3gb ram now but who cares.
BTW the place i found rom is at
Ladies and gentlemen, fosseperme present I made the first Android TV 7 port rom for our T95MAX, but I think it should works well on any Allwinner H6. I have entered a big number of optimizations for the processor, there is also Magisk, but it...
It s a t95MAX rom,
BT / WIFI works
yeah this is the rom I have installed, it is good rom, I have installed ftvlaunchx and nova launcher. I replaced the built in nova with updated nova and updated magisk. The box I have is an aeromedia Nanomax which is a t95 max clone.
does anyone know how to replace the missing 1gb ram if its possible?? . I've tried setcpu and kernel tuner to no avail.
Sent from my SM-G935F using Tapatalk
Originally posted by RiCkLaR_atvX View Post
Actually the ram can't be set at 4GB and run RAM correctly, so even though the board has physically 4GB-ram chips installed the board always runs at 3GB-ram, if you ever noticed the original firmwares it was never possible to have over 2GB-free-ram because the kernel can't correctly handle 4GB ram. Best to have firmware that shorts the 4GB to 3GB. I bought a 2GB-ram H6 device just test ram and it actually runs ram smoother than the 4GB device, but 4GB device has 5GHz WiFi so it stays plugged into TV.
The benefit of this would be, getting one of the dead usb ports back active and the clock display.
There are currently 1648 users online. 0 members and 1648 guests.
