(Desert names are dropped?)
Lineage OS Android 10 AOSP
***Untested***
Dev: sergej_a_g
Lineage-17.1 Android 10 AOSP to Mecool BB2 Pro 493 MB
https://4pda.ru/forum/index.php?show...64998&st=19360
The stock control panel turns the set-top box on and off,
Lan 1000 works.
There are no gaps.Apk install from the Files application.
(Flash via TWRP- as Google translated)
LineageOS 17.1
lineage-17.1-treble_a64-bgS_to_MECOOL BB2 PRO_by_sergej_a_g.img (with Gapps )
https://yadi.sk/d/5Rgv8QcntO_MGg
Acknowledgments:
2020-13-10
WiFi and bluetooth.
Lan 1000 works.
Bluetooth headphones connect and work, but when viewing the connection settings, these settings are crashed.
In the settings, the "Screen" item, we change the idle time before the console goes to sleep.
https://4pda.ru/forum/index.php?show...64998&st=19580
lineage-17.1-treble_arm64_bvS_to_MECOOL BB2 PRO_by_sergej_a_g_v2.7z
https://yadi.sk/d/IfNCtmMZZo9PzA
GAPPS (ARM64-Android 10-Micro?) are installed separately from here.
2020-07-08
Dev: Vasily Shevchuk
Info: (with subtitles
Android 10 to Mecool BB2 Pro -2020-09-13:
https://mega.nz/file/fIcBXCBY#RTtLXh1zBKsS6YQbmQI_OkAdnaEghhxOrK5MvDeqG 2M
Really good contributions, the firmware is a bit damp (raw , "a work in progress")
2020-15-10
Dev: Q8pro
Lineage-17.1 Android 10 AOSP with gapps
(Install from SD Card)
https://yadi.sk/d/3VNI0Pg1_KYfCA
