[Bricked] VONTAR X3 Amlogic S905X3 4/64GB
Originally posted by sagert View PostYou can load coreelec or alexelec from a memory card for the test.
Of course you have nothing to loose to try any method suggested. In another thread/topic I even have suggested (some time ago) that it is a good practice for everybody to have always an sd card ready with coreelec for such amd other usesSo yes try this also.
Dear freddy, I tried with all the temperature parameters and always the same result, for 7% of the formatting and when the time reaches 1:10, the error ...
Dear sagert and ath156, I tried to record the coreelec on the SD card, as per instructions, but not the image.
Dear Egc1010, I tried to press the passive thermal cooler, unfortunately it didn't work either.
I warmly thank everyone who is helping. I have a multimeter here, but unfortunately I don't even know where to start testing.
As for the heating with the hair dryer, as I said, I had tested it, but I heated it up a little bit, without exaggeration.
I ask, should I centralize the heating in the processor that must be below the passive cooling fan?
I also apologize for the English, I speak Portuguese natively.
Seguem imagens da placa:
So if you want to try, this is the chip to raise its temperature and immediately after try to flash the ROM.
And I repeat a couple of tricks you may try to overcome this 7% limit (before raising temperature of EMMC or even after that):
A. When it stops at 7% unplug and replug the USB-A cable (sometimes it continues the burning process)
or
B. Try to keep shorting the 2 pins even after burning process starts and even after 7% is reached (hoping that it will continue the process)
ath 156, I understood about heating. I will focus my attention on the KONSEMI chip, in my case I bought it as being 64gb.
about the short of the pins I even thought I was doing it wrong, because there is no signal when I short the 2. with multimeter I realized that energy passes between the two golden pins, little but it passes.
I will try to heat the KONSEMI ... put and remove the usb in the 7% also had not tested, I will try. thank you very much for your attention.
Originally posted by rootkonsole View PostAs for the heating with the hair dryer, as I said, I had tested it, but I heated it up a little bit, without exaggeration.
https://ibb.co/S5HD6vM
I did a quick research and I found out that this is true for all Vontar boxes. But problems like yours are found (to my knowledge) only to Vontars and not to HK1 Box. So it is not the board.
Also you have an Emmc by KONSEMI while other users, with the same problem, have an Emmc by Hynix. So it must not be the actual module/Emmc. Probably it is bad contacts (bad sholdering) of these modules.
So maybe the best bet to fix it, is still the heating (even slightly pressing ?) this module.
I also inform you that I recently bought a HK1 Box (so almost the same box as yours) but untill now everything is perfect. I hope it will be like this in the long run also.
Originally posted by ath156 View PostBy looking again more closely at your 1st photo I saw that although you have a Vontar X3 your Board is HK1 !!!!!!!!!!!!
Maybe Test Rom on Your Box rootkonsole
I like this theory about eMMc
However they flashed how many of these Boxes with Factory Firmware
And the solder only held once/one flash only?
You always have Good Advice/Tips ath156
Thx for your post
Originally posted by rootkonsole View Postuart, besides being difficult for me to get one, requires advanced knowledge, i don't know if i could. I tried again the methods suggested above and unfortunately, it doesn't work! I believe that if I don't find an electrical engineer, the TV box will not work again ...
He has posted reference to thread
As a last resort/last attempt
Otherwise maybe set this Box aside/Move on
This has been a Crappy Year Pandemic and all
Maybe treat yourself to a New/Different Box
Also the Jolly Old Elf is due for a visit soon !!!!!
As long as you have not been Naughty
Maybe could be New One Under The Tree
Happy Testing
Happy Holidays
salutation. thank you very much for sharing the knowledge and assisting in the solution attempt. I will try the heating method again. my usb cable is big, 1.5 meters, I doubt it is the cause, but it can even be ... the UART method is an option, but as I do not deal with it, it may be more an expense to acquire the UART that would compensate for taking a new box. any results, I inform.
There are currently 2728 users online. 1 members and 2727 guests.
