H96 max rk3318 red light
Hello, everyone, I was watching YouTube and suddenly my box got stuck and didn't work so I plugged out the power cable and when I plugged in again a red light inside the box got turned on and since then I can't use it I have tried to restore/update firmware but no luck I get error message test device failed and when I try the shortpin trick I get a message of prepare IDB fail. Please help me.Tags: None
Originally posted by freddy View PostTry this maybe
Boot to Recovery( Toothpick Method/reset button in AV Port)
You will need Mouse to navigate Recovery Menu(Sometimes Tv Box Remote works)
Factory Reset
Originally posted by freddy View PostForget PC for now
Connect just Box with HDMI Cable to Monitor/TV
Do You Have Video Display?
Anything?
Is thr Red Light at the back near Ethernet Port/ Or audio optic out
Greetings Elyas
So basically it Bricked itself while watching U-Tube
This is a fairly new Box ( 6 months or Newer?)
That suks....
Should Not Happen
There is not alot of support for this Box
Best if you Leave this Section
Which is RK 3328
Move to Rockchip 3318 section
There are Threads there to Read /Reasearch
People with same probs as You
Good Luck
There are currently 2502 users online. 1 members and 2501 guests.
