Look for boxtv A95x S912 A2 ROM
    A1_s912_v3_1 20170117//////A1s912(A2) 3G/32
      Originally posted by feras1989 View Post
      Maybe Try Search Engine
      Big GooooooooooooooooooooooA1_s912_v3_1 20170117//////A1s912(A2) 3G/32
      Add Factory Firmware to the end
      See where you are Directed Too
        Device is suspended when you boot up, you downloaded ROMs and are not compatible Thank you
          Is there any help?
            Nexbox A95X A2
            Lots of firmware! Below is option for Android 9
            Should work for your China Box. (I think android 7 bootloader/firmware should be applied first to your box)
            Make sure you know how to Unbrick your China Box before testing. Read everything..before jumping in.
            Android 9
            Dev:tehcno
            https://4pda.ru/forum/index.php?show...40#entry997191 13
            Slimbox-ATV-TANIX-TX92-Qualcomm_QCA9377_1000-ver10.2
            Посмотреть и скачать с Яндекс Диска
            Slimbox-AOSP-TANIX-TX92-Qualcomm_QCA9377_1000-ver10.2
            WiFi works very fast.
            Ethernet: Untested
            Bluetooth: Does turn on..untested
            USB: Hard drive transfer was 14 MBs (tested at setup). After a few reboots..or system setting- average 250KB up to 4 MB transfers.....
            Playstore: Did not properly see my purchased apps until restored by Titanium Backup.
            Viper4Android: Missing codecs and still must be turned on after reboot. Sound is great and Extra Loud is deafening.
            Remote:..Turns box, on anything else..untested
            Air Mouse: Rii i8+(2019) required sc keylayout files to work properly.
            TWRP: Untested but may require recovery patch to install(dev).
            Backdrop: Occasionally will send no signal..my Vizio TV shuts off after several minutes. China box is still running.
            CEC: Turned off: But must turn off TV and then immediately China Box, or box will reboot. Turn on TV- China Box starts up.
              Software does not match. With this device I upgraded it but it stops when flashing.
              Thank you
                Did you flash Android 7 first, (simplest way to get "Bootloader"?
                Then update to Android 9 (Uncheck "Erase Bootloader"?
                Either way 4pda link is for your China box, lots of Firmware there.
