Any rom or mod for x96 max plus that makes it look desktop?
Originally posted by webipsum View PostTry this app:
https://play.google.com/store/apps/d...rmerbb.taskbar
zozecilva
I don't know if it works in your box.
I tested on Tanix TX6s (Allwinner H616) and HK1 Box (Amlogic S905X3).
Did you enable the Freeform option (support for freeform windows), in the Taskbar app?
In one of the two, I don't remember which one, I had to give a command through a terminal emulator.
And the other options I configured according to this tip from the master ath156 <link>.
TASKBAR - FREEFORM
TASKBAR - SCREENSHOT
Originally posted by webipsum View Postzozecilva
???????I don't know if it works in your box.
There are currently 1506 users online. 0 members and 1506 guests.
