[ROM] Yundoo Y8 Android ATV 9.0
Thanks for the firmware. I installed it on my H96 max rk3399, everything worked great except for the WIFI and USB 3.0 port not working, , much better than the original android 7 firmware. I wonder if this firmware developer can modify it to make it work for H96 max rk3399, I'll be greatly appreciate!
Originally posted by ky312 View PostThanks for the firmware. I installed it on my H96 max rk3399, everything worked great except for the WIFI and USB 3.0 port not working, , much better than the original android 7 firmware. I wonder if this firmware developer can modify it to make it work for H96 max rk3399, I'll be greatly appreciate!
Originally posted by djdram View PostFirmware Yundoo Y8 Android ATV 9.0
Download link
RKDevTool_Release_v2.79
Thanks a million! Was about buying another box. Now my Y8 will have its 3rd life. Will install it this weekend. Thanks again!
*When upgrading from 6.x-7.x, you need to switch the device to Go Maskrom and do EraseFlash
Originally posted by ADD View PostGot wifi working. But ethernet does not work. Can any one confirm ethernet is working? How do I reflash firmware? Now I have TWRP recovery.
Edit: after reflashing ethernet still does not work...
Y8. Tried all, no luck. Whe static ip set, my router sees it, but internet. And I cant ping the device. The router also shows that the port is at 100mbps instead of 1gbps. No idea why. Checked all, no filters, no restrictions. Seems like a buggy settings app in rom itself.
Do you use 1.0 or 1.1 version?
There are currently 2828 users online. 2 members and 2826 guests.
