[ROM] Yundoo Y8 Android ATV 9.0
tried thisl Station P1 RK3399 AndroidTV 10 ROM
Station P1 AndroidTV 10 Firmware https://i.ibb.co/xfkdNF8/Homescreen.jpg Changelog v1.0 Add AndroidTV bootanimation Fix ATV Play Store Fix Youtube VP9 freezes Add Ad-blocker(blocks > 300000 sites) Add Kodi, Nova VideoPlayer, SmartTube Next, MiXplorer apps Grant storage permission for installed apps Changed default
got stuck on logo. Rolled back to 7.1. Would be great if someone could make this work on Y8.
Originally posted by ADD View PostY8. Tried all, no luck. Whe static ip set, my router sees it, but internet. And I cant ping the device. The router also shows that the port is at 100mbps instead of 1gbps. No idea why. Checked all, no filters, no restrictions. Seems like a buggy settings app in rom itself.
Do you use 1.0 or 1.1 version?
Any thoughts on how to put it up to 1Gbit? Thanks
Hello.
Probably https://wiki.radxa.com/Rockpi4/rockpi-android9 is a good start.
Also see: https://github.com/radxa/manifests/releases
However, I would like to know other details such as what is needed for the kernel or boot to make it work with devices such as Yundoo Y8. (Mine is R-TV K99)
Originally posted by djdram View Postdoes a Dev. support it ???
Made the firmware myself from the SDK sources, all works.
does your Y8 has Wifichip 6255
WiFi: AP6356S (WiFi AP6255 supported)
any Pictures ???
[ATTACH=JSON]{"alt":"Click image for larger version Name:\tScreenshot_20210311-105430.png Views:\t4 Size:\t44.6 KB ID:\t821297","data-align":"none","data-attachmentid":"821297","data-size":"thumb"}[/ATTACH
Just revived my H96 Max RK3399.
Wifi works.
Bluetooth devices seen(not tried).
720p Tubi stream plays video well.
Audio is not loud enough unless set to max?
System seems a tiny bit slow at first glance.
(Might play with root at some later date)
(Would prefer ASOP but a working device is better than trashed)
There are currently 2075 users online. 0 members and 2075 guests.
