I just got my new t-r42 but i think my problem has nothing to do with this device because it didn't work also with an older mini pc stick with an ethernet adapter.
Whenever i connect the ethernet cable, i can switch it on on the settings menu but thats it.
I use power line network because the router and modem are too far away.
This connection works with xbox360 or a different streamer but no luck with Android sofar.
Anyone?????
