Binary patched kernels for Pipo models
Originally posted by dark_lnt View Postif you appreciate my efforts this is the link for any donation:
Originally posted by rrileypm View PostI've done a new ROM for the M7 Pro based on firmware dated 11/2/13.
Any chance of a set of OC kernel's?
There are three kernels; stock with RAM clocked at 720, 1.7 GHz with RAM clocked at 720 and stock with RAM clocked at 720 and voltaged reduced to 1200mv to save battery.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
here are other different kernels mod for pipo M6pro to be tested (if someone is interested):
kernel_cpu1608h_gpu600_ddr800.zip
this is stock CPU and GPU and memory clocked to 800Mhz / 1.3V (I could probably push it to 1.375V if it doesn't boot)
any feedback is highly appreciated!Last edited by giouncino; 09 November 2013, 15:25.if you appreciate my efforts this is the link for any donation:
another one:
kernel_cpu1704h_gpu600_ddr720.zip
this is stock GPU
memory clocked to 720Mhz / 1.2V
The CPU is set to 1.704Ghz / 1.375V
again any feedback is highly appreciated!
If this works I've already generated another one with CPU clocked to 1.8Ghz / 1,375VLast edited by giouncino; 09 November 2013, 15:25.if you appreciate my efforts this is the link for any donation:
Originally posted by A64 View PostHi darrellr,
any chance to tweak the M9Pro (3G) a bit ? CPU to 1.7-1.8, maybe RAM as well if that brings something.. what about GPU ? Or stupid Q ?
Repeated here (stock CPU/GPU, RAM clocked to 720 MHz and voltage reduced to 1200mV)Last edited by d33; 09 November 2013, 17:35.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Thanks for the M6P and M7P kernels....I'll start testing them.Randy
Originally posted by giouncino View Postanother one:
[ATTACH]3919[/ATTACH]
this is stock GPU
It has already booted and it's a good start, I will test for some time and I wil post results.
Thanks darrelr (and giouncino of course)
Claudio
- if I'm using RileyROM 2.0, am I already using this kernel ? (Stock CPU/GPU, faster RAM, lower voltage) ?
- voltage reduced: is that voltage for the CPU or for the RAM ?
- any other versions maybe ? The tablet isn't hot at all, not even warm.. maybe could have more CPU and GPU if needed. Just curiousity..PiPO M9 Pro 3G - RileyROM 2.0 (8GB internal storage) -
- any other versions maybe ? The tablet isn't hot at all, not even warm.. maybe could have more CPU and GPU if needed. Just curiousity..Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
[QUOTE=darrellr;111624]I do not know what you have flashed, only you know
I understand iptables better, than how's RileyROM configured for my tablet- I flashed it (because I trust him and have nothing to lose), I thought somebody knows the parameters.
I've fiddled about a bit and managed to squeeze a little more out of my M8HD
CPU - Stock
GPU - 666 MHZ (Stock+10%)
RAM - 768 MHZ (Stock+45%)
This Combo gives AnTuTu of 20, 500 (+11% on stock)Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Just to see if the M9 Pro can use the same settings I'm using on my M8HD I've created two more test kernels for it.
M9 Pro Riley Rom 2.0 Patched kernels
1. CPU 1.6 GHz, GPU 666 MHz, RAM 768 MHz
2. CPU 1.7 GHz, GPU 666 MHz, RAM 768 MHz
Download from dropboxMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by claro966 View PostJust flashed RileyROM 1.3 (thanks Randy!) with this oc kernel .... let's see!
Claudio
your mod kernel seems to run well, really
from the beginning I haven't any freeze or stuck and neither lags and the pad is more responsive.
Not significantly increase of battery juice!
Just as a test, should be use to test something like:
CPU 1.7 GHz, GPU 666 MHz, RAM 720 MHz (cool)
or
CPU 1.8 GHz, GPU 666 MHz, RAM 768 MHz (extreme)
let me know if you can carry out something else on RileyROM v1.3 of course
ciao
or
ciao
My objective is to prepare the kernel with fastest frequency without an increase of voltages!
I'll prepare new kernel files as soon as i have a little bit of spare time
Stay tuned,
Ciaoif you appreciate my efforts this is the link for any donation:
There are currently 2088 users online. 0 members and 2088 guests.
