[ROM] Slimbox Gt King Pro (Android 9)
    Hey guys, Is this FW working on the new wifi6 version ?
      I have tried, This rom doesn't work on wifi6 version
        New test ROM
        SlimBOX version 12.1 ATV
        Beelink GT-King Pro
        , based on GTKing PRO 918P0 wol bt from 2021 04 28
        Dev:Slimhouse
        https://slimboxtv.ru
        *** Google Assistant might not work ***
        update 12.2 coming soon
          "slimBOXtv version 12.2
          Dev:SlimHouse
          Firmware rebuilt based on the latest update 923P0
          Changes:
          • Corrections to the dark theme
          • Corrections in the work of spdif
          • System optimization
          • AOSP keyboard with voice search
          • The city of Kiev in the choice of time zones
          • Sharpness in advanced picture settings
          • Updating built-in applications
          • System amendments
          The firmware uploaded: follow the site! "
            Available as ATV or Pie
              slimBOXtv project 2021
              ATV and PIE firmware for S922X processors have been updated!
              v12.2 (updated)
              Changes:
              Fixed start logo
              Image scale changed to 280 dpi
              System amendments
              Download Firmware
                TWRP temporary
                10/22/2021 SlimHouse
                TeamWin recovery ( TWRP ) is a modified unofficial recovery that is released for most Android devices.
                Much more powerful than native recovery. Creation and restoration of a backup copy of the firmware.
                Instructions:
                1. Download TWRP .
                2. Copy to a SD card or USB flash drive.
                3. We go into the stock recovery.
                4. Move to the item " Apple update from EXT "
                5. Then to " Update from sdcard or Update from udisk ", depending on the location of the downloaded TWRP .
                6. Find the downloaded TWRP and select it.
                Attention:
                On TV boxes with a 912th processor, the correct recovery of the Vendor partition could not be defeated . Therefore, we also backup the Vendor Image section , which must additionally be restored separately !!!
                Download: TWRP AML SlimHouse 3.5.2
                  slimBOXtv 14
                  Dev:SlimHouse
                  Changes:
                  • Installing patches from settings
                  • Fixes for problems with sound
                  • Fixed a soundbar bug when activating services in special features (ATV)
                  • Added USB settings, animation speed
                  • Advanced Bluetooth settings
                  • Added support for Vulkan (s905x2, s905x3)
                  • Added the code for the AFR_CALC button to the Key remapping application
                  • Configuring AFR_CALC in Application Key remapping
                  • System amendments
                  Firmware will be uploaded soon, follow the site!
                  Review, approximate configuration of slimBOXtv PIE firmware
                  Review, approximate configuration of slimBOXtv ATV firmware
                  Download Firmware:
                  Don't know if there was a v13? ?
                  ** There may be a need to change DPI if task bar appears on the right side of screen.**
                  In developer's section (?) set the image scale to "default" (240 dpi).
                    slimBOXtv 14.1
                    Changes:
                    • Added installation of Super light version slimBOXtv to additional functions
                    • The Autostart application has been moved to the installation in additional functions
                    • Pressing again on the setting in additional functions will work as deleting
                    • Added setting Limit processor frequency when playing video
                    • In About device, the item is added to the version of the factory firmware
                    • The LeanKeyKeyboardPro setting item has been added to Keyboards
                    • Updated Busybox
                    • Updated timezone files
                    • Fixes for HDR
                    • Setting Screenshot mode works after overload
                    • Codification of system applications and services
                    • System amendments
                    Download ATV or PIE
                    For similar info:
                    https://forum.xda-developers.com/t/p...imbox.4152049/
                      slimBOXtv 14.2
                      Changes:
                      • Added font selection to settings
                      • Corrections with voice search
                      • Added image optimization, makes the image clearer (the opposite effect is possible)
                      • Installation of additional functions only after enabling root access
                      • Built-in OTA system update, check and download
                      • New logo and butanimation
                      • System amendments
                      Download ATV or PIE
                      For similar info:
                        slimBOXtv 14.5
                        Changes:
                        • Added Disable TVLauncher item to additional functions
                        • Amendments to OTA update
                        • Menu button fixes
                        • System amendments
                        (OTA update - very very nice to download updates through system as opposed to flashing whole firmware! )
                        ((Current firware via OTA is v14.6.2 )
                        Download ATV or PIE
                        slimboxtv.ru
                        For similar info:
                          Changes in version v14.6.3
                          Cumulative Update
                          * Happy New Year!
                          * Important critical update in order to receive OTA in the future
                          * OTA is divided into three types - ATV, PIE, LITE
                          Download 2_5373128168901186860.zip for free from ufile.io instantly, no signup required and no popup ads
                          Contacts:
                            wrong theread to post. Please delete
                              slimBOXtv 14.7
                              Changes:
                              • Fixed config remote for G20s BTS
                              • Changed the option to install the light version of slimBOXtv
                              • Added ad blocking with host to settings
                              • Added to settings using Google DNS servers
                              • Added network speed improvement in settings
                              • Added mouse cursor selection
                              • Added background selection in TVLauncher (ATB)
                              Download ATV or PIE
                              (Full update)
                                slimBOXtv 14.7 (Updated)
                                • Changes:
                                ​​​ updated firmware, built on the basis of the latest 925P0 update
                                Download ATV or PIE
