[ROM] Slimbox Gt King Pro (Android 9)
    (Topic carried in forum: [ROM] ugslimtv Gt King Pro (Android 9)
    https://forum.freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s922x/others-s922x/firmware-roms-tools-dq/827864-rom-ugslimtv-gt-king-pro-android-9
    Ugoos mod 042.4
    Changes: Ugoos kernel (?)
    Firmware for revision P0_ ?
    (Same files/folder as Beelink GTKing. Testers beware)
    Download ATV or PIE
    https://slimboxtv.ru
      slimBOXtv 14.8
      Dev: SlimHouse
      Changes:
      • Added an option to select the type of the recent window
      • New logo and bootanimation
      • Added Image Scale item - ATV or PIE
      • Volume control step 65
      • Image enhancements
      • Updating and replacing built-in applications
      • System amendments
      Download ATV or PIE
        slimBOXtv: suggested optimal settings from SlimHouse. (Russian language )
        Overview, approximate firmware setup slimBOXtv PIE
        Overview, approximate configuration of the slimBOXtv ATV firmware
          slimBOXtv 14.9
          Dev: SlimHouse
          Changes:
          • Added advanced reload to settings
          • Amendments to themes, using the best optimal colors
          • Fixed Bluetooth settings
          • Update built-in applications
          • System amendments
          Download ATV or PIE
            first of all this is by far the best custom rom for tv boxes especially the pie version for me is ******* hot, i have one question hope someone can answer!
            i saw in a video that slimbox supports OTA.
            I`m at the latest version 14.9 and i can´t finde OTA updates in settings i can see Patches tho.
            if a new version comes out do i install thru Patches or ?
              Unfortunately, OTA has been removed from current firmwares.
              Not sure if patches will be available instead of full image updates.
                thanks, for the Informations, i have another question, i used the temporary TWRP from slimbox website to backup my settings and everything, there are so many partitions to click, do i need every single one of them? what are the Importen ones to get a good backup for my settings and rom?
                  TWRP Back-up:
                  Back-up everything...in case
                  In the past: Boot, System, Data.
                  Now I believe you should include: Vendor
                  It is confusing!
                    Alright thanks a lot for the infos!
                      • slimBOXtv version: 15
                      • CPU: Amlogic S922X-H
                      • GPU: Mali-G52 MP6
                      Changes:
                      • Added additional Bluetooth settings with displaying the battery charge of the remote control
                      • Increased the display size of the logo and boot animation
                      • Added AOSP keyboard with default Holo Blue theme
                      • Corrections to the operation of image modes
                      • Added optimally tuned Nova Launcher mod, activated as master (PIE)
                      • Involved Google services with less memory and CPU usage
                      • Key remapping has been modified in the Button Manager and is launched from the settings
                      • System amendments
                      Clean installation is strongly recommended !!!
                      Download ATV or PIE
                        slimBOXtv 15.1
                        Changes:
                        • Added support for Bromite SystemWebView (download from the project website)
                        • The AOSP keyboard startup icon is hidden
                        • Replaced Setup Wizard (ATV)
                        • Fixed issue with logging in to Google account
                        • Updated WebView and Google Play service
                        • Added additional Bluetooth settings with the display of the battery charge of the remote control
                        • Increased logo and boot animation size
                        • Added AOSP keyboard with Holo Blue theme by default
                        • Adjustments to the operation of image modes
                        • Added optimally configured Nova Launcher mod, activated as master (PIE)
                        • Google services with less memory and CPU usage are used
                        • Key reassignment has been modified in the Button Manager and is launched from the settings
                        • Systematic amendments
                        • Added support for Bromite SystemWebView (you can download it from the project site)
                        • Hidden launcher icon for AOSP keyboard settings
                        • Replaced by Setup Wizard (ATV)
                        • Fixed issue with google account login
                        Download ATV or PIE
                          slimBOXtv 15.2
                          Changes:
                          • Added information panel in the form of a window
                          • Added image scale adjustment (dpi)
                          • TVLauncher disconnected from market updates (ATV)
                          • TVLauncher enabled third-party launcher (ATV)
                          • Updated firmware
                          Download ATV or PIE
                            slimBOXtv 15.3
                            Dev: SlimHouse
                            Changes:
                            • Cursor, font selection corrections
                            • Translation into Russian added in settings
                            • Program display (PIE) fixed
                            • Additional options in Device Settings - Power
                            • Added Ugoos voice search by default
                            • System amendments
                            Download ATV or PIE
                            (Xda members post - Might have errors with settings?)
                              slimBOXtv ATV AOSP version 15.4
                              Dev: SlimHouse
                              Changes:
                              • Amendments to the installation of fonts, cursors
                              • WebView 103.0.5060.71 from LineageOS
                              Installer of APK files with displaying the number of the current and updated version of the application
                              • Activation of ATV UiMode for programs in settings (AOSP)
                              • Activate bootvideo or bootanimation in settings
                              • System corrections
                              Download ATV or AOSP
                              slimBOXtv
                                slimBOXtv 15.4.1
                                Changes:
                                • Fixed non-work items in the settings
                                • Amendments to the activation of Ui Mode for applications
                                • Disabled influence of commands from LG remotes
                                slimBOXtv
                                https://slimboxtv.ru​​
