Android_12 for X96 max plus2 4gb/64gb
I can't say this 100%. But I took it from the 4pda website in the X96 Max + topic. And there this file was already checked for functionality, of course. But I have nothing to check it on now. You can go to that site in the X96Max + topic and find this firmware file yourself. What more can I say? Don't know.
If something does not work, you can replace dtb in recovery in the firmware and boot to your dtb. But first, replace one digit in your dtb - this is the size of the system partition. This figure needs to be increased, because the system will not fit. The firmware can be easily parsed with utilities such as Xvortex. I don’t remember now, but the number was 50,000,000. You can see exactly if you open my dtb, then there will be another number, so put that one. It is clear that the dtb needs to be converted into dts to read this dtb. And after editing the dts, convert it to dtb.
There are currently 2982 users online. 1 members and 2981 guests.
