Android_12 for X96 max plus2 4gb/64gb
Originally posted by sagert View PostThe firmware has been updated. Now gapps are already working. The dtb in twrp has also been replaced. The link in the first post. Twrp works.
https://github.com/s1a1g1e1r1t/Andro...905x3/projects
Ethernet
Wifi
Bluetooth
And TWRP !!!!
However this is Andrew 11
Not 12
Have tested
300g Nexon X8
306 - gapps SU
And Latest 400 a - gapps
For Android 11 i would probly use the Nexon X8
Iam going back to your original Firmware 12 with no gapps
Thank you for posting
More Testing
Happy Testing
Originally posted by freddy View Post
Testing yesterday
Ethernet
Wifi
Bluetooth
And TWRP !!!!
Not 12
Have tested
300g Nexon X8
306 - gapps SU
More Testing
Happy Testing
Originally posted by sagert View PostThere were some minor graphics problems, but phhusson recommends adding the following line to the /system/build.prop file:
debug.sf.latch_unsignaled=0
After that, the graphics, especially in games, became normal.
I assumed you mean edit the existing string to read as...=0 > disable
Change 1 to 0 in existing.( This is what i did)
Or add new string?
I see from AiDa64 and From Build.Prop Board id..=
ro.product.board= A95X_F3
platform = franklin
manufacturer = Droid Logic
So really good odds your Firmware will work on all those A95X_F3 China Boxes..
Thank You sagert for posting
More Testing
Happy Testing
Hmmmmm
Or add new string?
platform = franklin
More Testing
Happy Testing
It shows where this line is being edited and inserted. Of course, first you need to make a backup in the twrp firmware before that, so that if anything is restored. I myself noticed that the graphics were a little twitching in games. Now after this change, the graphics are in order.
Here is the edited build.pror file that needs to be replaced in this path. This line is already written here.You also need to set the correct permissions for this file. This is 0600. And after that it will reboot. It's just so that it doesn't need to be flashed again.
Yes, I took the vendor section from the A95x F3 firmware. Therefore, it writes like this. These readings are taken from the vendor. I liked this vendor also because the correct set of remote control buttons. So I took it into this firmware. Maybe this prefix is also possible with minor amendments work on android 12. To make it work most of all, you need to use your dtb in the boot, recovery, _aml_dtb sections.
Greetings sagert
I have applied the changes
I want to learn what is changed
I have questions
What is the function of this string /effects graphics?
This string debug.sf. latch_unsignaled=0
This string exits in Vendor Build Prop and is enabled...=1
WE have added this string to system build prop and disabled...=0
Why can we not disable in vendor build prop?
Instead of adding to System build prop and disabling?
CPU reads from vendor build prop for Boot/startup?
CPU needs this function enabled in vendor for Boot/startup?
Then after success CPU reads from system build prop for normal TV Box functions?
What happens to vendor build prop?/mergred with system build prop?
Apoligies for confusing questions
I like to learn
More testing
Happy testings
I have questions
I like to learn
More testing
Happy testings
I myself first changed this value in vendor from 1 to 0. But then the box was not loaded simply. Then I began to add this line to /system/build.prop and the graphics stopped twitching in games. I play backgammon and there were problems with graphics. And after writing this line in /system/build.prop, the graphics stopped twitching.The fact is that phhusson makes its own images for many devices, but our boxes seem to be a little slow and it is better to slow them down on the advice of phhusson.
Originally posted by sagert View PostIf you read here what phhusson wrote in version v400a, then it says about it:
Thanks for reply
I just realized you replied
This was posted the day of/ hours before Freaktab was supposed to close for good
Have been following phhusson work
All released files since have that string
sf latch...
Automatically enabled
This rom still works great.!!!
Have been testing slimbox on my Tanix S905X3
Happy Testing ?
Hello freddy.
I didn’t come across Slimbox. Yes, I tried to do atv. But I didn’t succeed. For example, if you just roll onto android 12 with twrp gapps tv 12, then several programs don’t work there. What subtleties are there to make them work, I don’t know how much is needed experiments. And gapps tv 12 is installed only the smallest package. The other one is not installed at all. I also found how to convert the firmware to atv. There is a link :
For wifi and bluetooth to work properly, you need to replace the dtb.img file in recovery.img and boot.img with your own dtb.img. Even before that, its dtb.img must be edited there by increasing the size of the system.img partition. To do this, you need to use the kitchen. And for editing dtb.img there are separate programs, it seems they are on github. Yes, this is a rather difficult task.
There are currently 3217 users online. 0 members and 3217 guests.
