can't flash a firmware :(
Hi.
Make the path to firmware short... ( As most flash tools are dos commands )
Like : c:/install/firmware.img
Don't forget to run the flash tool as administrator
Do you get a green block at connected devices? ( Because screenshot shows no green or red block )
Does windows show...new device found? When connected
Try different usb ports and cables...
Goodluck
GoodluckMake the path to firmware short... ( As most flash tools are dos commands )
and still nothing
I have newest version Rockchip Driver Assitant 5.1.1 installed
Originally posted by JoseM View PostFactory Tool always Prepare IDB Fail
btw TV Box is working fine it isn't bricked
Other times you might need to erase the flash first and then fw do the "upgrade" button.
But be very careful you can brick the device when you do the erase flash...Last edited by superceleron; 15 March 2022, 16:32.
There are currently 2736 users online. 0 members and 2736 guests.
