Envoyé de mon GT-I9500 en utilisant Tapatalk
New stockrom mk808b
Impossible to download
Originally posted by ylber View Post
Thank you.
Originally posted by Adainair View Posthttps://docs.google.com/file/d/0B0Ko...?usp=drive_web
I did not have time to test it yet but i am upload it to drive here is link
By the way @ylber thanks for sharing information
Originally posted by SpicySaturdayBoy View PostI've got difficult time to download from that website. It's very slow and stop download afterward. Can you share your downloaded ROM or any trick to download from that site.
Thank you.
then, i dont know why but from almost all servers i get my max speed
and when i don't, then i download the link twice at the same time
most of the time one of the download then got downloaded with the max speed, in my case 1 mb / sec
Re: New stockrom mk808b
Hey guys couple of questions I'm hoping you can answer for me:
-) how does this rom compare to the custom roms? I'm currently on digitop's and wondering if it's worth the switch
-) are Netflix and xmbc definitely confirmed working?
-) how do you flash it?
Thanks,
Sent from my awesome fridge using Tapatalk 2
Nice 4.2 ROM with many new things
Originally posted by benjyz View PostHey guys couple of questions I'm hoping you can answer for me:
Thanks,
Antutu test still make this unit hot (3D test) that put device to reboot itself so I still haven't have Antutu score. Epic Citadel run at 1280x720 with 39.3 fps. Also test with my 3TB HDD with Silverstone enclosure TS07 worked flawlessly can play 1080p mkv file without any problems. I posted couple of pictures from this ROM. I hope someone can patch this ROM to be full 1080p.Last edited by SpicySaturdayBoy; 06 November 2013, 14:56.
Only 720p?
If this is 720p only, it would be a bit of a backwards step from 406j205_09_2013. In that version (which came on the device), you can go onto the Screen settings and choose 720/1080 and 50/60.Last edited by nhathaway; 06 November 2013, 15:37. Reason: I think it's screen settings (not display)
Everyone should install this rom http://www.freaktab.com/showthread.p...0730)-_Sep2013
It's the fastest and most updated at the moment. it's Android 4.1.1 and 720p.
The update_mk808b_407j2404_overseas.img rom doesn't have much improvement from Finless 2.1, the only difference I could find by inspecting the files were
- Nand driver updated
- bt usb module included
- hid multitoutch module included
- Assign TCP buffer thresholds to be ceiling val
- Includes Youtube App, Twitter, skype, settings.app bigger than app in Finless 2.1 rom
- Rkvideoplayer updated from 20130108 to 20130516
- Rkgamecontrolsettings.apk & Rkappinstaller.apk included
All the other files are the same as in Finless 2.1 rom that was released in May.
Originally posted by mo123 View PostEveryone should install this rom http://www.freaktab.com/showthread.p...0730)-_Sep2013
There are currently 3967 users online. 2 members and 3965 guests.
