With sixaxis app it doesn't work touch emulation.... i set a profile but it appear only a little hand and doesn't "touch" the screen.... anyone tested this?
New stockrom mk808b
2 topics?
Originally posted by ylber View Post
Originally posted by benjyz View PostHey guys couple of questions I'm hoping you can answer for me:
-) how does this rom compare to the custom roms? I'm currently on digitop's and wondering if it's worth the switch
-) are Netflix and xmbc definitely confirmed working?
-) how do you flash it?
Thanks,
Sent from my awesome fridge using Tapatalk 2
1) It's a pretty good stock rom with Android 4.2.2
2) YES Netflix from the app store works perfectly! I had previously flashed Finless 2.1 but Netflix didn't work on that. An older version of Netflix did, but it froze constantly..that's why I went back to the stock rom.
3) To flash, download Finless rom package and see the readme. Follow the instructions, except use the RKBatchtool 1.5 included in his alternate flashing folder. You basically connect the device to your PC (OTG port) and install the Rockchip drivers. Once your PC recognizes the device, you then run the RK Batch tool, press "Switch" to get it into batch mode, and then click "upgrade" to flash the stock rom. Let it run until the device reboots and you're in the new rom.
Originally posted by luxor1971 View Post1) It's a pretty good stock rom with Android 4.2.2
I will have to replace the launcher, what is the best to get? On Finless 1.7 I used the stock Android 4.1 launcher which suites my needs. The stock on on this ROM does not because it cannot be configured.
Originally posted by Amarok74 View PostWith sixaxis app it doesn't work touch emulation.... i set a profile but it appear only a little hand and doesn't "touch" the screen.... anyone tested this?
There are currently 2063 users online. 0 members and 2063 guests.
