Amlogic S912 Octa-core 64-bit Cortex™-A53 up to 2GHz 36800 DMIPS | |
Operating system | Android 6.0 Marshmallow |
RAM | DDRIII 2GB |
Flash | EMMC 16GB |
GPU | Multi-core high perf 3D ARM Mali-T820MP3 GPU up to 750MHz (DVFS) |
Wifi | 2.4G/5G WIFI support 802.11.AC up to 866Mbps |
Help needed / Rom search
hey guys this is my first post hopefully I chose the right forum. I have a freestream stream genie eliteand looking to upgrade my firmware. apparently the OEM is keeping everything under wraps and can't find a thing on it. does anyone have this device and we're u able to get an ota and if so how or is it even worth trying. thanks in advanceTags: None
Originally posted by pbsipher3 View Posthey guys this is my first post hopefully I chose the right forum. I have a freestream stream genie eliteand looking to upgrade my firmware. apparently the OEM is keeping everything under wraps and can't find a thing on it. does anyone have this device and we're u able to get an ota and if so how or is it even worth trying. thanks in advanceAmlogic S912 Octa-core 64-bit Cortex™-A53 up to 2GHz 36800 DMIPS Operating system Android 6.0 Marshmallow RAM DDRIII 2GB Flash EMMC 16GB GPU Multi-core high perf 3D ARM Mali-T820MP3 GPU up to 750MHz (DVFS) Wifi 2.4G/5G WIFI support 802.11.AC up to 866Mbps
i moved your Post into a own Thread in S912 Section , the Problem with this "no Name" stock Boxes is ,
mostly no Firmware Support , you only can search for a S912 Firmware with the right supported Specs ,
S912 / 2/16 / and the correct Wifidrivers for your specific Wifichip , what Version ever ??? ,
good luck / gefattern
Hi ,
thanks for the answer back and a little bit of your time. this is all new to me, well amlogic anyway. I am familiar with Android and Qualcomm. what the purpose of wifi drivers? do i need that for flashing or something else? just curious because so far only way I found to flash was through wifi debugging which my device does not have come standard
the Wifidrivers are included into Rom , so if you flash the wrong one , no Wifi or
Ethernet , you only need the right Firmware , open your Box and look for Wifichip .
Hi ,
I will do that and get back to you this evening
There are currently 1958 users online. 0 members and 1958 guests.
