Just purchased an Ugoos X4Q Pro.
Very new to this equipment.
My TV is an older Sony Bravia KDL-40R550C.
Is there a general setup for tv boxes?
Things one should and should bot do in setting up?
The user guide is very brief.
I have it hooked up to TV, but would like to know if there is a forum tab on setup?
Maybe a link someone found helpful?
Ugoos X4Q Pro Amlogic S905X4 Android 11 TV Box ReviewPurchase at lowest here - https://s.click.aliexpress.com/e/_DEbwP03Price Comparison page - https://wp.me...
freddy I am having some luck getting it set up, however one little problem I am having is that the on screen keyboard that shows up on my TV
is too wide and I cannot see all the keys. Any idea how I can change that? I went into settings>resolution and settings>position but was
unable to make the on screen keyboard smaller. Is it a problem with the TV or the android box?
Couple of things to try maybe will help
In Settings
Display
Screen Resolution
Turn Off /Auto switch to Best
Set your Resolution Manually 1080p or 720p
Also in Settings Display/Sound
Look for Screen position
Should be Settings for scaling
Zoom in Out
Also in Sony TV
Can try changing aspect ratio
Or advanced settings like picture view
Zoom/fit to screen//wide view/etc..
