HK1 Mini RK3329-D4-V02 - hard bricked in maskrom mode - Test Device Fail
    Hello,
    I have a hk1mini RK3229-d4-v02 20180613 in maskrom mode. All softwares are able to see it, but non of them is able to write a firmware, anytime it fails on Test Device Fail. I've tried on Win7 and Win10.
    10:53:09 371 Layer<4-3>:Test Device Start
    10:53:09 402 Error:RKU_Write-->WriteFile failed,bRet=0,err=31,size=31,write=0
    10:53:31 746 INFO:RKU_ResetPipe-->DeviceIoControl OK
    10:53:36 777 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
    10:53:36 793 <LAYER 4-3> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-3),path=\\?\USB#VID_2207&PID_320B#5&2C96EA2E&0&3#{ a5dcbf10-6530-11d2-901f-00c04fb951ed}
    10:53:42 793 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
    10:54:05 058 INFO:RKU_ResetPipe-->DeviceIoControl OK
    10:54:10 092 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0​
    Originally posted by rocky5 View Post
    Hello,
    Hi ,
    maybe the Loader is bricked or more , did you tried the SDWay to restore or boot
    from SD , maybe the Haizenberg Way works for you ,
    Steps for repairing IDB failure are: 1-use Andriodtool v 2.51 or higher 2-you have to have a working loader (you can unpack any working rom using andriodtool by going to _Advanced Function_ and from here download a working firmware and unpack it by pressing unpack. Note, you can find the (loader) in (output folder created by
    good luck / gefattern
