Please I need MXQ PRO S 8K stock firmware RK3229
    Hello friends. I bought many MXQ Pro S 8K rk3229, 128gb, android 12 but they all came with details on their operating system. I install their applications and they close quickly. The boxes are too slow. I did their hard reset but they are still the same situation. The worst thing is that official firmware don't appears anywhere. Can anybody help me?? Thanks. And sorry my English it's a little bit. I speak Spanish.
    Sure is Rockchip 3229 ????
    With Android 12
      With Android 12
      Hello. Yes it's rk3229 with rk30sdk(Board)
        OK
        will have a look
          Thank you so' much. I send the photos with the information.
            No luck finding any firmware
            One reference was Bangladeshi????
            From images you posted
            I see firmware is Android 7.12
            Maybe this is the result when you did Factory data Reset
            As you posted
            Unfortunately there are many MXQ TV Box
            And also some shady vendors that sell knock offs
              As you posted
              Hello brother. I took the first photo from the internet but the second photo was taken by me. I'm from Puerto Rico and actually, I had bought some boxes in a store in Dominican Republic some time ago that they had on clearance sale and they had no warranty. They all came with the same problem. Super slow and the apps don't open it. The firmware does not appear anywhere. I'm going crazy. I need to repair them urgently.
                OK
                if was clearance sale
                Then take box apart and post images of PCB top and bottom side.
                So can confirm chipsets
                CPU
                Ethernet
                Wifi/bluetooth
                Then can steer in right direction for working firmware
                  Click image for larger version  Name:	IMG_20240603_170724354.jpg Views:	0 Size:	115.1 KB ID:	834262
                  OK
                  CPU
                  Ethernet
                  Wifi/bluetooth
                  Thank you so' much. I appreciate any help. God bless.
                    OK
                    from images
                    To right if CPU with heat sink glued to top
                    Is SanDisk Nand/Flash...
                    Can't make out catalog #
                    type serial number in browser wil tell you what size is
                    1/8
                    2/16
                    Your wifi module is SV 6256P
                    Any markings sticker on underside of board?
                      The box have 8gb + 128gb
                        Hmmmmmmmm.
                        8 and 128 running Android 7.12 ?????
                        More like 1/8
                        However
                        My suggestion is test
                        ATV 9 TechLife Rom
                        At the top of page
                        Click on RK 3229 Devices
                        Move down to thread
                        ATV 9 TeckLife Rom by esdras
                        Good luck
                        ​​​​​​​Happy Testing
                          Hmmmmmmmm.
                          More like 1/8
                          However
                          ATV 9 TechLife Rom
                          At the top of page
                          Move down to thread
                          Good luck
                          Happy Testing
                          That's exactly what's strange situation. The box itself says that it comes with Android 12 but in that application "Device info" it detects that it has Android 7.
                          Edit:
                          So far only the ATV 10 version has worked for me & not the ATV 9. The big problem it's mistakenly recognizing 4 GB of storage when the TV boxes are actually 128 GB. ATV 10, work very nice.
                            Edit:
                            Exciuse me, where did you find the ATV10 version?
