Cube U30GT 2 v2.06 20131017 900supersportROM
can not flash
Originally posted by 900supersport View Post
Originally posted by galinvas View PostI'm trying to flash yr ROM but the toolkit says that "MSC can't erase NAND". When I Reboot2Flash the kit says " no device detected". The tab should be switched on in order PC to detect it but then the kit can't do upgrade. Could u pls help?!900Supersport
freaktab developer
fixed
Originally posted by 900supersport View Postwhat os are you using? have you tried a different USB port and or cable?
tab stood on the screen with the following info "Resistance is futile."
Originally posted by 900supersport View PostHere's a ROM for the cube U30GT 2 RK3188 based on Cube U30GT 2 v2.06 20131017
Cube U30GT 2 v2.06 20131017 900supersport ROM
Notes- Flashing will delete everything on your Cube consider backing up first and remove any sdcard
- Download and extract to a folder
- connect the tab to the PC (you did remove the sdcard)
- start the ROM flash tool
- put the tab into flash mode, the PC should detect it, see below for instructions
- install drivers if required
- erase idb
- flash, the ROM kit is correctly configured
- the tab should boot to recovery and format cache, data and sdcard (this will take a few minutes)
- the tab should now boot
So what do you get?- defaults to english uk
- root
- bloat removed
- busybox and init.d support
- play/market fixes for more apps in Google Play
- LatinIME keyboard
- a choice of 4,6 and 8 gig app space, 4 is the default but the others can be selected from the flash tool
- Power off the Cube
- hold Vol + and connect to usb
- After 3 to 4 seconds release Vol +
- The Cube should be detected by the PC.
- If you have not already installed the drivers now would be a good time. I've included the drivers in the ROM kit in the RockusbDriver folder.
Hello,
Can you help me? I started the process of changing the ROM, but the tab stood on the screen with the following info "Resistance is futile."
I can not log to reboot.
HELP
Tnk You
I've not used Bluetooth on the tab, I'll see if I can take a look.900Supersport
freaktab developer
Mouse now working
Originally posted by ncmoody View PostTHANKS - what a swift reply, I would appreciate anything you can suggest.
thanks for letting me know, I'll be attempting to bind to some Bluetooth speakers later.900Supersport
freaktab developer
Wi-Fi turning off during sleep or lock
So, I finally get a new charger and I'm back on my Cube to give this ROM another shot. Everything is great still except I have been having an issue where the WiFi keeps shutting off when the tab sleeps or locks. I have it set to always be on, but it still is doing this.
Lastly, I thought this ROM was running smooth before, but I have been noticing it "Lag" up a bit now that I have installed a couple standard apps that I would have normally installed before with no issues.
Do you have any suggestions on the WiFi issues I have ran into? Thanks so much! Love the 900supersportROM series!
For those that want/need cifs or vpn support please see http://www.freaktab.com/showthread.p...nel-based-ROMS
Also for clockwork recovery see http://www.freaktab.com/showthread.p...r-Cube-U30GT-2900Supersport
freaktab developer
There are currently 2948 users online. 0 members and 2948 guests.
