[ROM][CWM][NeoX5]Minix_4.2.2_20131106_root_reboot
    I did a quick root and added a reboot app to the latest Stock Minix FW.
    Wrapped it in a CWM-flashable .zip and uploaded it to hotfile and rockchipfirmware.com.
    I try to do the same to the 1080p Version next week.
    You need a CWM installed already. If you don't have it, get it here.
    I did what I did with as much attention as possible, the modded FW is installed and running propperly on my device.
    As there is a chance that you kill your X5 by using the provided FW, you should have a working backup and knowledge to recover it.
    Use it at your own risk.
    Please give feedback
    Thanks, I installed it and worked perfectly
      Is the ROM in German only or can it be switched to English. looking for English version.
        You should be able to switch in settings.
        If not, please open/system/build.prop with root explorer or sth. similar, and change the lines
        Code:
        ro.product.locale.language=[B]de[/B]
        ro.product.locale.region=[B]DE[/B]
        to your liking. Save and reboot.
        Please let me know the results.
        Regards Chris
          this offer still valid?
            Just uploading it to hotfile... i have forgotten to do so, sorry.
            Link follows.
            Regards Chris
            Edit: Here we go... 1080p version with root and reboot.
            If the ui is too small you can edit the build.prop, add or change the line:
            ro.sf.lcd_density=160 to ro.sf.lcd_density=240
            But as always, be carefull and have a backup ready.
              Link follows.
              Regards Chris
              Thanks look forward to!
                Link follows.
                Regards Chris
                Could you please upload to different site, they shut down hotfile
                  Here you go:
                  CWM_X5_4.2.2_20131106_root_reboot_deDE_1080.zip - 266.67 MB
                  CWM_X5_4.2.2_20131106_root_reboot_deDE.zip - 266.67 MB
                    Awesome!
                      Help
                      I wanna test this Rom and flashed it to my x5
                      Before Fineless 1.2b works fine
                      Wipe / Factory Restore
                      Install Rom via CWM
                      Wipe Davik
                      Now i only got the MINIX bootlogo all time long
                      Need help
