The firmware filename indicated "pure" version, which I discovered was a Chinese release with no bloatware added to it...no extra apps, no Pipo Launcher, no nothin'......
This ROM is:
An optional kernel is named ockernel.img in the RileyROM folder, you can flash it by clicking the browse box next to the kernel line in the flash tool and highlight the ockernel.img file.
If you want to switch kernels back and forth, you can without having to re-flash the whole ROM by unchecking everything but the kernel in the flash tool....and don't erase IDB before flashing. This overclocked kernel has been tested by a few users and runs quite well and makes a huge difference in speed, however there is a certain amount of risk associated with overclocking (much less flashing a custom ROM in the first place)...so think about the consequences...such as increased battery drain and overheating and death (of your tablet, not you). (I know, it sounds like a drug commercial...but I gotta say it...hahahaha!!!!)
I do recommend that you flash the whole ROM the first time and do erase IDB when you do so.
This ROM is:
Rooted
Debloated to the max (already done by Pipo)
Init.d Support
English Default
Busybox commands added
CWM Recovery as an option
Multi-User support added
4, 8 or 12gb user app space as an option.
Bootanimation by Tattman65
Reboot app by Petrus
First Time User's Guide by Pr0xZen
Flash Tool by Finless
Download
I also ported the system of this ROM for the OLD PCB tablets. It still has the same old kernel, but there may be some improvement. Just compare and see.
Old_PCB
Enjoy!!!!!!
If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
