[Collective Thread] CS968, CloudnetGo CR11s, TV01, UGOOS UG410
    mitglied and TVDroid.
    Here almost everything perfect.
    cfwtool.exe... worked nicely.
    4x Erase NAND (IDB)... ok!
    Lowers the screen flutter (flashes).
    But I can not set 1080p (1920x1080).
    Screen goes black and returns in 1280x720 (720p).
    Original firmware for my CS968 allows 1080p.
    Any tips?
    Note: Hello to Switzerland and Germany.
      AW: [Collective Thread] CS968, CloudnetGo CR11s, TV01, UGOOS UG410
      Hi Brazil,
      are you sure that your screen does support full hd?
      JDfense
        Originally posted by JDfense View Post
        Hi Brazil,
        JDfense
        Yes.
        My TV is FullHD.
        Tks.
          This is with my Stick too, only on PC Mnitor 23,5" Full HD works, on my 42" TV its makes the same as webipsum. But both have FULLHD.
          ... TVDroid
          > > > Devices: Minix Neo X7 & HiSilikon® T-R42 II < < <
            My 32 inch full hd has so fare no problem with the tv01 box. I will check the other roms. Which one is the best ?
            JDfense
              Test this when you want, this what we use now and this is the newest.
              ... TVDroid
                What do you mean with pre rooted, fully rooted or not? Which stock rom is the base?
                JDfense
                  Pre-Rooted = Full Rooted but Root before installing the ROM = Pre-Rooted. Not my Idea, but i see ths many Times in the Android Area.
                  Base - http://blog.geekbuying.com/index.php...ndroid-tv-box/
                  PS: Kannst mir auch ne PN senden, dann können wir deutsch quatschen
                  ... TVDroid
                    Okay. This stock rom is on my tv01. I'll check your rom
                    JDfense
                      [Product Review]
                      webipsum
                      CS968 - JESURUN
                        Good work TV Droid, but it seems the TV01 stock has no 1080p.
                        Lets see what the cloudnet kernel can do.
                        Edit:
                        Cloudnet has a 1080p kernel.
                        JDfense
                          Edit:
                          JDfense
                          Hi JDfense.
                          Cloudnet has a 1080p kernel?
                          Curiosity:
                          The CS968 is connected to my TV LG 42LG80FD by HDMI cable.
                          Only works 100% in HDMI3.
                          On HDMI1 and HMDI2 unsigned.
                          CS968 (original firmware of factory).
                          webipsum
                          CS968 - JESURUN
                            Edit:
                            JDfense
                            What you mean ? You test a other ROM and this works in 1080p with your Device ?
                            Or you just flash a other Kernel ?
                            Thanks!
                            ... TVDroid
                              reconfigure actions of color buttons on stock ir-remote
                              the stock infrared remote controller have nice row of color buttons under power/mute buttons. how to configure actions for that color buttons? i would like to launch es file explorer, mx player, etc instead of useless chineese trash.
                              thanks.
                                Thanks!
                                Hdmi resolution depends on kernel and cloudnet has it for both versions (2MP and 5MP). It could be possible to mix the ROMs, when they use the same source. But it will be not enough to change kernel, I think.
                                Needs more investigation.
                                JDfense
