[Collective Thread] CS968, CloudnetGo CR11s, TV01, UGOOS UG410
Get started:
Rename the image you want to install to update.img and copy it into the same folder as the tool. (Thank you hanu_blr!)
1. Start the Tool
2. Press 1 for Unpack and 2x Enter
3. Press 3 for Pre-Root and Enter
4. Press 2 for Pack everything and Enter
5. Press 3 for rk3188 and Enter
The pre-Rooted ROM named now "misk8ercfw.img" and you can flash it.
The tool can be found here:
http://forum.xda-developers.com/show....php?t=2489040
Is there a CFW tool that will work on x86?
Originally posted by TVDroid View PostYes but after a Reboot its Stock again.
TVDroid´s CustomROM V.0.2 / S400 / TV01 / CS968 / AP6210 WiFi
Base: http://blog.geekbuying.com
Changes:
+ Pre-Rooted
+ Spoof as ASUS Nexus 7
Download >HERE<
edit- There was a little box I was suppose to uncheck before downloading.
@ Hanu_blr
Just click on Firmware and download what you need.
http://www.myhdplayer.de/Android-TV-Box/CloudnetGO-CR11S-Android-4-2-Quad-Core-Mini-PC-inkl--2MP-Kamera---Mikrofon.html
... TVDroid
> > > Devices: Minix Neo X7 & HiSilikon® T-R42 II < < <
Originally posted by Sirian View PostAll those links at that website are broken. I've tried numerous times.
** note: the cloudnetgo ROMS are not rooted
Help With Pre-Rooting?
Originally posted by daveh0 View Posti was able to download the 5mp 1080p ROM from http://en.cloudnetgo.com/_d275908309.htm. I recommend using Chrome so that it automatically translates the Chinese to your language.
on a similar note, if anyone can pre-root the cloudnetgo 5mp ROM and post it for download, I'd be most appreciative. I currently do not have an x64 system to run the CFW tool on.
Thanks in advance,
-dave
I would say video playback is good, but not perfect. The 720p kernel versions are running a bit faster, but with the 1080p you get the real sharp hd screen. Possible that it is only my impression, but the rom with 1080p kernel is for me the start for improving a ROM.
I can't say something about the video stream standards, because I haven't tested it.
I have noticed that the 1080p has some trouble with flash, but I don't know why - so far.
JDfense
There are currently 2484 users online. 3 members and 2481 guests.
