While cleaning up some old apps on my tablet, I noticed that some of the apps I recently installed from the Play Store say that they're not compatible anymore, yet will sideload just fine. Play Store has also recently updated itself from 3.5.14 to 3.5.15.
Could THIS have anything to do with that happening? Has anybody ELSE ran into this issue? What do YOU folks think might have happened?
Now that we have Shawn's ROM, I will reflash back to stock, reroot, and reinstall the Finless Play Store files - once I get home and have the time - to see if this fixes the issue. If so, I'll disable automatic app updates.
I will go scoop up a 701i tomorrow, if I can find one. THIS time, I will be keeping THIS ONE stock, to help out with the development of the 701i ROM.
73 DE N4RPS/3
Rob
