I am trying to use my Logitech Harmony Remote with this device and am not having any luck. I have also tried to put a cheap windows media center receiver on it and tried to use that to work with the harmony and neither the media center remote or the harmony worked. Does anyone have any ideas for this to work. it would be great to have only one remote to mess with. I use the K-R42 using lewy's 2.0.4 rom with an alpha build of XBMC Gotham. Thanks again.
K-R42 with Logitech Harmony Remote
All,
I am trying to use my Logitech Harmony Remote with this device and am not having any luck. I have also tried to put a cheap windows media center receiver on it and tried to use that to work with the harmony and neither the media center remote or the harmony worked. Does anyone have any ideas for this to work. it would be great to have only one remote to mess with. I use the K-R42 using lewy's 2.0.4 rom with an alpha build of XBMC Gotham. Thanks again.Tags: None
i use the "flirc" adapter (www.flirc.tv) with my Logitech Harmony, works perfekt with any Xbmc version.
Regards from Germany
GerdCS918 with v1.1.1 justXbmc firmware from lewy20041
Out: HDMI
In: Logitech K400R keyboard, Flirc adapter for XBMC and Logitech Harmony
Originally posted by givecredit View PostI just used the learning facility on the Harmony to learn the remote commands of the K-R42. Works perfectly.
A bit of an hassle..
The Samsung SMT-100t in the Logitech Harmony software is chosen.
Installed Key Test and identified the key ID for each keys identified.
Added the missing keys on the Harmony remote by learning the IR codes with the Harmony software
Edited the rkxx-remotectl.kl file to get the most functionality out of the keys available.
What is now missing is the ability to edit the remote.xml or the keyboard.xml under XBMC
If I make any changes to /sdcard/android/..... or /data/data/..... it is not picked up by XBMC application
Anyone know how those xml files can be edited on those Android boxes?
There are currently 2107 users online. 0 members and 2107 guests.
